Panasonic FP-7113 Plain Paper Copier
I am getting the wrench signal that my copier needs routine maintenance. Can I do this myself? It is working fine other than the flashing wrench.
  • Anonymous Mar 14, 2009
    Where does the developer go in one of these copiers?
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Service Time imageunit can be removed with two screwsand remove tank before lifting out. You can remove drum and cleaning blade section yourself 4 screws. Two on the cleaning and two on the removablr pins on the side.Then remove blade with two screws and fit cleaning blade and drum and reinstall.
Service manual for service mode to remove spanner display F9 ??
Cheers Justin
Posted on May 01, 2008
  • howlingtunes Oct 19, 2010
    so how do you get rid of the damn wrench symbol?
  • justin Oct 20, 2010
    You can keep using it, not a problem. Service time will require a number of parts and will cost around about $500.00
How do I repair error E3-22 Exhaust Fan Problem on Panasonic FP-7115
Do you have can air remove covers exit side of machine, clean vents and remove dust from fans!. If you can remove the fans to clean them better then blowing dust into the machine!!!
Nov 05, 2014 | Panasonic Toner for FP 7113, 7115/S, 7713,...
Wrench code Panasonic fp7728 copier
PM service is needed. reset counter in service mode 7
Jul 18, 2014 | Panasonic Fp 7728 7850 Compatible Copier...
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
Good Luck and Thank You for using Fixya.
Dec 31, 2010 | Pitney Bowes C180 Copier
Normally the wrench symbol indicates that certain parts are near the end of their usefull life.
Such things as Developer, Drum, Cleaning Blade, possibly also parts in the Fusing unit such as the Heat Roller or Press Roller...this will depend on make and model and the number of copies on the machine.
Think of it like your car, you know that you have to change the oil,Transmission fluid, Brake pads, Tires etc, etc, etc,...but for a time the car is still running OK even tho' these parts are due to be replaced, you can keep driving till your brakes don't work at all, or the engine blows because you didnt change the oil; ...I think you get my meaning....its your choice when you want to do the maintenance...the machine just has an indicator to tell you when IT thinks it has run the appropriate number of copies for certain items to be replaced.
Oct 18, 2010 | Panasonic Office Equipment & Supplies
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Help me with a code reset panasonic fp7713
Press paper tray, zoom down key, and #1 keys simultaneously. "F1" displayed. press 8, start,then 09, start. DV will run auto for 3 min. hit stop/clear. F7-22 to clear PM count.Press stop/clear until F1 displayed. Press paper tray, zoom down, and stop/clear to exit maintenance mode.
Sep 08, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Apr 15, 2008 | Office Equipment & Supplies
Do you know how to explain error code for Panasonic Plain Paper Copier FP-7722 E 7? Our copier locked up...
I believe you have a temperator warm up issue, when does the error ocuur after initially turning on, if it's within 120 seconds or less it's probably a fuse if after it's probably a lamp.
\Thank You,
Apr 03, 2008 | Office Equipment & Supplies
442 people viewed this question
