Question about Polaroid iZone 300 Digital Camera
Changing battery..can't find
Camera will not hold charge...about 2 yrs old..can not find how to change battery..can only remove memory card...everything else has screws???
  • 8 more comments
  • Lynnrob Jun 02, 2008
    Camera will not hold charge - can you change batteries? if so, how? thanks!
    Lynn R.
  • alexus ellis Jun 23, 2008
    i have the same problem with my camera i had it for about 4 months then one day when i tried to charge it up it didnt charge at all i was wondering if there was some way i could get a new battery if so can someone tell me and were is the battery located in the camera and how does it look
  • polaroid_cam Jul 28, 2008
    I have a Polaroid izone 300W camera, and the flash doesn't work, and the battery runs dead all of the time.
    I know that the battery is a Lithium-ion Polymer Battery, but how do I change it?
  • Anonymous Jul 29, 2008
    the izone 300 camera has only been used twice for about 10 pictures. now the battery won't stay charged. can you purchase a replacement battery for this camera?
  • Anonymous Oct 10, 2008
    battery will not stay charged
  • eli_ana Jan 09, 2009
    My battery doesn't charged... how can I get another battery???
  • jandh909 Feb 01, 2009
    how do i replace battery on polaroid izone 300
  • Anonymous Mar 19, 2009
    camera will not stay charge know longer than10 min.,it works fine other than that
  • Anonymous May 07, 2009
    doesn't stay charged, says low battery
  • rme24 May 20, 2009
    Can someone who got this to work please let me know where they got their batteries? I took mine out but can not find anything even close.
    Bob
I took my izone 300 apart and replaced the battery with one purchased from Digiplant on Ebay for $9.98, shipping included. The battery is a Lithium Polymer 3.7 volt, 280 Mah, but I used a 3.7 volt, 550 Mah. It improves the battery life immensly and the flash never fails like it did on occasion when it was new. Hope this helps everyone looking for a replacement battery.
Posted on Nov 25, 2008
I took the camera apart via shadowligers vague instructions. I found out the camera has 3 screws on the bottom, 2 are underneath the sticker. so that is how you don't break it taking it apart. The camera is held together with the screws only so once you take out all 11 screws you are good to go. the battery says tjl 402334 280mah on it.
hopefully I can get a replacement on ebay or something.
Posted on Feb 22, 2009
  • 4 Answers
This is not a complete solution to your battery problem but hopefully its enough to help you since polaroid has the worst customer service possible.
http://img.photobucket.com/albums/v411/shadowliger/0806080007-00.jpg
the link above is a picture of my izone 300w who at the moment is suffering from the battery problem as well i decided to open it to see the battery. though if you decide to open it i suggest you not only be mildly forceful but all so cautious since the bottom where the card slot may break.(some small pieces snapped off. )
the battery is the small silver thing you see in the picture. this battery is 280mAH battery its small and almost as thin as a credit card. if you want to change the battery try looking for one that looks almost the same or try and mp3/mp4 player battery. for example zen micro. i suggest looking through the internet for the internal batteries but if that search fails buy a cheap small rechargeable mp3 player that you wont feel so bad about breaking and taking it battery.
hopefully this helps. good luck
Posted on Aug 06, 2008
After opening up the izone 300, were you able to replace the battery?
Posted on Aug 11, 2008
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
How to solve the problam of lens obtructed?
If the camera was dropped this fix will not help you.Otherwise try changing the batteries
4. Verify:
Feb 08, 2011 | Kodak EASYSHARE M1063 Digital Camera
Directions for changing battery
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
6. Replace back case, and then replace screws.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
Will not hold charge. put in new battery and fully charged it. Lasts about 5 minutes. Use dock. Is this the problem?
How long have you had your dock and batt.?
They might be in a need of a change.
Here are the steps:
1. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
2. Turn on your camera without the memory card.
Mar 13, 2010 | Kodak EasyShare C875 Digital Camera
My camera won't turn on, changing the batteries/cleaning the contacts hasn't helped. It was fine last night, and i can't see how it would've been knocked or damaged, i was careful!
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 17, 2010 | Kodak EasyShare C140 Digital Camera
Why does the camera not turn on? i only used it 3x, changed batteries 4 x and still wont turn on is only 2 months old
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 14, 2009 | Kodak EasyShare C913 Digital Camera
I have a great Mavica FD75 camera and the batteries will not hold a charge. When I put them on the charger the light says lit for a couple of minutes then goes out. I can take 6-10 pictures and get the...
You probably need a new Sony "Infolithium" battery, by now. The battery lasts a long time
but 10 yrs IS a long time! If you've never repl
aced the battery, it's time to. They charge ok
but don't last very long when they're near the
end of their life! (Sounds like what you're
describing.) The little disc battery only works
the memory for the Date / time / etc.
Jan 04, 2009 | Sony Mavica MVC-FD75 Digital Camera
Lost date and time data
I had the same problem, the best solution that I found, was to make sure that I put the new batteries in with 30 secs, and the date etc, remained at the correct time.
Jun 09, 2008 | Fuji FinePix S5500 Digital Camera
Camera says battery empty
When you finished chargin the batteries, was it fully charged? Are you using the AC cable that was provided to you witht the device? if your camera showed that it was fully charge but discharge even though you dont use the camera,I would recommend you to replace the batteries on the device....
Jan 17, 2008 | Olympus FE-210 Digital Camera
Cameras Logo
1,407 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
