Question about GE WSXH208A Front Load Washer
Internal Filter Is there a filter infront of the pump which I should check everyone now and then to make sure there is nothing blocking the way to the pump? I see in the diagrams there is a filter cap. Do I take that off to clean it out?
    Genius:
  • 1,073 Answers
Yep make sure that you do not have water in the machine and pull it away from the wall so you can lean it backwards to keep it from getting water on the floor
Posted on Apr 30, 2008
Maytag maxima XL washer is not spinning out the water how can I fix this?
Pump, filter or drainage problem.
Check there is nothing jammed in the pump or the filter.
Make sure the drain is not blocked or running "up hill"
Mar 14, 2016 | Maytag MHW6000AW Maxima XL 27" White Front...
Truck would not excellerate pas ten miles now it wont start. when i play with the fuel restart button it starts rough and dies
See there were several postings. Was internal fuel tank screen good when pump was changed? Was disposable fuel filter changed? I had similar problems and it turned out that the internal filter screen broke apart and clogged the fuel lines.
The crankshaft sensor was also bad as fuel pump was tested during internal tank filter work.
Also check your injector wires. Even having fuel pressure is nothing if the injectors are not opening to let fuel into the cylinders.
Dec 27, 2013 | 2007 Mercury Mountaineer
Has no suction
The intake, filter, or impeller may be blocked. Make sure the filters are clean, and intake pipe has nothing jammed in it. Also when trying to get it going, make sure the pump is well primed, which means the intake water level must be as high as possible, and the skimmer box and intake filter basket must be full of water.
Aug 29, 2013 | Pool & Spa
2001 CHEVY MALIBU WONT TURN OVER, UNLESS YOU SPRAY STARTING FLUID ON IT, THEN IT STARTS FOR A FEW SECONDS. HOW DO YOU REMOVE THE LINES IF IT IS THE FUEL FILER TO REPLACE IT.
lots of notes in here about overheating cars, everyone wants to replace the thermostat thinking that will fix it, but it never does. likewise lots of folks thinking their fuel filter is blocked solid. it is so seldom the fuel filter. There is a filter on the fuel pump take up before it even gets to the filter so they just are not going to get totally blocked up unless the gas tank is corroding away on the inside. but your issue does seem to be a fuel supply issue. i would be thinking more about the fuel pump or pressure regulator than the filter. have someone check the fuel pressure at the injectors.
Sep 19, 2011 | 2001 Chevrolet Malibu
I want to change the oil on a 2007 Rav 4 Where do I access the oil filter?
the filter is either under the exhause in the front, just infront of the oil pan, or it could be under the plastic cover on top of the engine in a housing that would an internal filter.
Feb 18, 2011 | 2007 Toyota RAV4
All of the de is sitting in the bottom of the filter tank. When I bump the handle it feels as if there is nothing in the filter. I checked the C clips and they are ok. This is when I noticed all the de at...
If you water flow back to the pool is slow, there are several things that you can try with these pool filters. First, make sure that there are not blockages or clogs in the return lines. Next, make sure that you filter grids are not dirty/have holes. It could be that you simply need to replace the grid material. Make sure that your impeller is not blocked. Finally, check to be sure that it is not a voltage problem.
Jul 05, 2010 | Hayward EC-40 DE Pool Filter with pump
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
I need to remove the fuel filter land rober 2004 freelander
changed my fuel filter yesterday,it can befound infront of the offside rear wheel attached to a plastic cover by to bolts,
Apr 04, 2010 | 2004 Land Rover FreeLander
Filter is running with very low psi
First make sure your gauge is reading correct. Put your hand infront of the pool's return..if it feels good and strong, then the gauge could be bad. An air leak somewhere in front of the pump could also be a problem. Check all hose clamps, o'rings in any unions or valves infront of the pump could be bad or missing or the cover gasket on your pump basket could be bad
Jun 14, 2009 | Hayward Pool Products 25 Sq Ft Micro Clear...
Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Apr 24, 2008 | Asko W6021 Front Load Washer
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
