WESTINGHOUSE TOP LOADER WASHER
I just replace the center rubber seal , and carefully install all connectors and hoses back , plug it in for a test to check for leaks , it fills up to desired level BUT doesnt want to start , I hear like a hum coming from the motor and a strange smell , I recheck all connections , plug it back , NOW it wont do nothing , not even fill the tub with water , so theres 2 things to check a fuse ? and why motor wont start , It was fine before. please help AJ
    Genius:
  • 1,028 Answers
Be sure motor turns freely also ckd wires to motor if motor should overheat safety in motor opens and water won't run in
Posted on May 01, 2008
CALL A TRAINED SERVICE PERSON
Posted on Jul 17, 2008
Need to replace heater core
Heater Core REMOVAL & INSTALLATION
1978 and Later Without A/C
  1. Disconnect the negative battery cable and drain the cooling system. CAUTION
    When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  2. Disconnect and plug the heater hoses from the core tubes.
  3. Disengage the electrical connectors from the module case.
  4. Unbolt and remove the module's front cover and lift out the core. To install:
  5. Install the core and apply sealant to the module cover, then install the cover and secure.
  6. Engage the electrical connectors to the module case.
  7. Remove the plugs, then connect the heater hoses to the core tubes.
  8. Connect the negative battery cable, then refill the engine cooling system and check for leaks.
1967 and Later With A/C
  1. Disconnect the negative battery cable, then drain the engine cooling system to a level below heater core. CAUTION
  2. Disconnect and plug the heater hoses at the core tubes. Plugging the hoses will help prevent excessive coolant leakage.
  3. Remove the module's rubber seal and screen. If necessary, disconnect the washer nozzle from the cowl.
  4. If necessary, remove the right windshield wiper arm.
  5. As applicable, remove or disengage, the diagnostic connector, high blower relay, thermostatic switch, ground strap and/or electrical connectors from the heater core module cover.
  6. Loosen the retainers and remove the module's top cover. The cover is sealed to the module and this seal must be broken before the cover can be removed. Be absolutely sure that all cover fasteners are removed before attempting to break the seal or cover damage will result. Take your time and be careful not to force and crack or otherwise damage the cover. NOTE: On many late model vehicles, cover interference with the vehicle's bulkhead will may removal difficult. On these vehicles it will be necessary to loosen the windshield's chromed lower trim plate for the necessary clearance.
  7. With the top cover removed, loosen or unclip the core retainer, then carefully lift the core from the vehicle. To install:
  8. Thoroughly clean the mating surfaces of the cover and the module of all old sealer.
  9. Install the heater core to the module and secure the retaining bracket.
  10. Apply a coating of sealant to the cover, then install the cover and tighten the fasteners. If the windshield trim plate was loosened for clearance, reposition and secure it.
  11. Engage the electrical connectors and components to the module cover, as applicable.
  12. If removed, install the right wiper arm.
  13. Install the module screen and rubber seal. If removed, install the washer nozzle to the cowl.
  14. Remove the plugs and reconnect the heater hoses to the core tubes.
  15. Connect the negative battery cable, then properly refill the engine cooling system and check for leaks. Fig. 3: Loosen the clamps, then disconnect the hoses from the heater core tubes 85946010.jpg Fig. 4: Remove the rubber seal from the module top cover 85946011.jpg Fig. 5: Loosen and remove the module cowl screen retainers 85946012.jpg Fig. 6: Make sure all of the screen retainers are removed, some like this one, are on the side of the screen 85946013.jpg Fig. 7: If necessary, remove the retainer and reposition the washer nozzle 85946014.jpg Fig. 8: Some retaining bolts may be partially hidden, check under the wiper arm 85946015.jpg Fig. 9: With all of the fasteners removed, carefully lift the screen from the top of the module 85946016.jpg Fig. 10: Disengage all electrical wiring and components from the top of the module 85946017.jpg Fig. 11: Loosen and remove the module top cover retaining bolts 85946018.jpg Fig. 12: As with the cowl screen, the top cover bolts may be difficult to find 85946019.jpg Fig. 13: If the windshield's chrome trimplate interferes with cover removal, it will have to be loosened or removed for additional clearance 85946020.jpg Fig. 14: Remove the bolt and bracket from the passenger side of the trim plate 85946021.jpg Fig. 15: With the bolt and bracket removed, the trim plate support may be removed for clearance 85946022.jpg Fig. 16: Once all of the bolts are removed, break the seal by lifting the top cover from the module 85946023.jpg Fig. 17: Remove the core retaining bracket; in this case by loosening the retaining bolt 85946024.jpg Fig. 18: Lift the heater core from the module, but remember it still may contain a fair amount of coolant 85946025.jpg prev.gif next.gif
Oct 13, 2010 | 1982 Chevrolet El Camino
Need instructions to replace door latch-kenmore elite top loader
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Roper washing machine the drum is loose and makes lots of noise
remove the drum unit and check out as follows: Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
2. Loosen two screws that hold weight on back half and slide out weight.
3. Remove drive belt. Cut wire tie, unplug motor and leave wiring in the bottom of the washer. Remove 4 screws/bolts that hold on motor and remove motor
4. On front right, loosen screw and remove rubber drain trap from tub. Squeeze large snap ring and remove water level sensor ( thing that looks like an old fuel filter ) from rubber drain also. Remove little hose from top of water level switch also. ( NOTE: You can also disconnect the level switch hose at the top of the washer. This will make it easier to re-connect, however you'll need to be careful that you do not damage the hose when you remove the tub assembly ).
5. At this point, you might want to remove the motor control board and pump motor assembly. Each is secured by 2 screws and are easily removed. This will prevent accidental damage and give you more room inside the washer to work with. There are 2 connectors on the control board and 1 on the pump motor � be sure to remove those first.
6. Shocks, push the lock tab to allow the pin  to be slid out of the tub and the shock will be free from the drum. ( picture help one and picture help two )Push pins through to the rear and remove. The baskets will now be hanging from the springs.
7. From top, twist out the tube from top of the outer tank. Place support under drum. I use 2 blocks of wood.
8. From front, carefully cut the glued spots where the door seal is glued to the front panel and remove the fill spout holder clip. The tools used is a piece of copper tubing flattened down. I use a wire tie to reinstall as the metal clip can be a pain to work with!
9. Drum should just be hanging from 2 large springs. Remove the clips/spring holders that go over the top of the springs so they can be lifted and removed from the washer. Start on either side, lift spring, move toward center and lower to disconnect drum from the frame. Completely remove spring. Repeat on the other side. Drum should now be sitting on the supports.
10. From above, lift drum and slide out the rear. Leaves you with an empty cabinet.
11. Lay drum on front face on a blanket or sheet and start to remove screws that hold halves together. Once all screws are out, the back half with pulley (top half if sitting on face) easily lifts up from the other half.
12. Remove and replace tub gasket seal. New seal will appear thicker than old one. The old seal can be picked out with a small flat screwdriver.
Assembly.
13.  Place supports in bottom of washer. Lift and slide drum back into place on top of supports.
14. I use a zip/wire tie to go around the water fill tube where the spring clip was and then cut the leftover tail off of the zip/wire tie. I remove the 2 screws holding the plastic hose in place to make installing the wire tie easier. Push the rubber boot over the plastic hose and use the wire tie to secure the boot to the plastic hose. Helps to install drum support springs (big ones on top) first.
15. Install safety clips back over springs. Glue the top hose back into place.
16. Front assembly reverse of disassembly.
17. Back and Motor assemble reverse of disassembly.
18. Finally, pull the boot over the front of washer. Don't do this until drum is in fully, or the boot might not end up on straight and might twist a bit. Small spots are re-glued again in place, super glue works well for this.. Spot glue at the 12 o'clock, 1, 2, 3, 4, 5, 6, 7, 8 and 9 o'clock positions around the opening.
19. Put on back and top.
20. Run load, check for leaks. Note: back panel is structural and should be on for a load to be run.
21. Should be done. Total time 3+ hours. I hope this helps anyone who has to get into the Frigidaire -Kenmore ( 417.###### ) front loader and replace the seal/tub bearing&shell or inner basket.
Bearing and Seal notes:
Tips for removal / replacement of inner tub....
1. After removing the back panel and drive belt, remove the pulley from the shaft. The bolt is removed easily, but we often have to gently pry around the base of the pulley to remove it (unless you have a puller). The pulley is very light and the metal is soft, so be very careful that you do not damage or bend it while prying.2. The inner tub will lift out once you have split the outer drum halves.
3. Remove the 3 tumbling fins from the old inner tub. The new tub will not include these, so you'll need to reinstall the old ones. They are held on by one or to screws each. *Careful* of the outside of the wash basket as it is VERY sharp!!
May 07, 2009 | Roper Washing Machines
Drum does not rotate once machine turned on
remove and check the drum gasket: Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
Assembly.
May 07, 2009 | Washing Machines
Having trouble dismantling the motor / gearbox from the tub base of a 7244E washing machine, to replace the drive coupling. I have the 3 mounting screws out but can't withdraw the motor/gearbox assembly...
Assembly.
May 07, 2009 | Whirlpool Washing Machines
WASHTUB PROBLEM
Assembly.
Change is moving around under the tub how do I get it out
1. Bring Band-Aids, Frigidaire seems to leave many sharp edges!! Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
Assembly.
May 06, 2009 | Frigidaire ATF6000ES Front Load Washer
#285352 Trust Plug (Input Shaft) Seal R&R
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven’t done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o’clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o’clock position.
- With both hands gradually work your way around to the 4 and 8 o’clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking taps
Check first if leaking from hoses or under the machine.
Undo your taps, check that the hoses rubber seals haven't worn out. Replace rubber seals, most hardware plumbing sections have them. Also if the actual tap is leaking at the wall, you will have to change the tappets. You will need to close your main water at the timer, then undo the actual knobs, depending on the tap. Once opened take out tappets and replace with copper ones rather than plastic. Then put all back together and switch water on and check if leaking. In case it is the washing machine, try to replace hose or the connector on the back of machine. Make sure also all rubber seals are replaced with new ones. If under machine you will need a plumber. See how you go!
Aug 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
