Question about Epson TM-H60000II Thermal Printer
Error light on a Tm-H6000II
I get a Red blinking light by the error signal and yet I have all the connections good. The printer will not advance paper or print.
  • 2 more comments
  • Thriftywhite Apr 30, 2008
    I get a slow blinking light that fades in and out. I am using a parallel connection.
    There looks like this and it blinks every 6 seconds.
    I am not sure I quite understand what you want me to try given the error code that i attached.
    I did recheck the auto cutter and it is okay. The error has a solid red light and then blinks once every 6 seconds
    Genius:
  • 1,447 Answers
Whats the pattern of the blinking light? can you pls describe...
what type of interface are you using, USB, SERIAL, PARALLEL, ETHERNET?
Posted on Apr 30, 2008
  • 2 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 30, 2008
    whats the exact pattern? 4 slow blinks then off or 3 slow blinks then off?
    Here are some other error indication
    IF THIS DOESNT HELP TELL ME THE EXACT PATTERN, THANKS!!
    Try this, IF it doesnt help email me back
    Yep try to check the autocutter on your unit.
    Here are the patterns and error indicators
    blinks 6 times and turns off
    1. receipt cover open
    2. slip printing receipt cover is open
    3. card ejection error
    blinks every 6 seconds on-
    printer head temperature- turn it off for an hour, then turn it back on.
    auto cutter if it blinking 6 times continuously and turns off then blinks again after 6 seconds
    Get the memory utility from this link: EPSON
    you will have to register first so that you can get a username and password. then go to technical resources and select printer model
    ************Some info if your getting cover sensor errors
    Printer Cover Sensors
    Receipt section
    ❏ Paper roll cover open sensor:
    • When a paper roll is selected as the print sheet, if the sensor detects a cover open during
    printing, the printer goes offline, stops printing immediately, and the ERROR LED
    blinks. Even if the cover is closed, the ERROR LED still blinks. You need to transmit the
    error recovery command to recover.
    If the printer continues printing, it starts printing from the beginning of the line where
    the error occurred; therefore, double printing or printing position shift may occur. It is
    recommended to clear the buffers and resend the print data.
    • When a slip is selected as the print sheet, if the sensor detects a cover open during
    printing, the printer finishes printing data for the line when the cover open is detected,
    then stops the carriage movement and goes offline. The printer goes online when the
    cover is closed and restarts printing.
    ❏ Unit cover open sensor:
    • When the sensor detects a unit cover open during printing, the printer goes offline
    depending on the setting of bit 8 for the memory switch.
    The default is that the printer finishes printing data for the line when the cover open is
    detected and stops printing. The printer goes online when the cover is closed and
    restarts printing.
    If a recoverable error is selected by memory switch, the printer goes offline, stops
    printing immediately and the ERROR LED blinks. Even if the cover is closed, the
    ERROR LED still blinks. You need to transmit the error recovery command to recover. If
    the printer continues printing, it starts printing from the beginning of the line where the
    error occurred. In this case, double printing or printing position shift may occur. It is
    Front cover open sensor:
    • When the sensor detects a cover open during printing, the printer finishes printing data
    for the line when the cover open is detected, then stops the carriage movement and goes
    offline. The printer goes online when the cover is closed and restarts printing.
Tm h6000II
I guess it lacks either a thermal roll or something's wrong.. like.. error code? check your printer software, usually displays an error code or says what the problem is
Jul 24, 2013 | Epson TM-H60000II Thermal Printer
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Usb connect-it problems.
Do you power off before you connect all attachment
Dec 13, 2008 | Epson TM T90 Printer
RE: Epson TM-U200 printer with error (2 Flashes)
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Cheque stuck in tm-h6000II
try this- remove the ribbon and try to pull specks of paper
May 28, 2008 | Epson TM-H60000II Thermal Printer
Epson TM-H60000II Thermal Printer Logo
2,684 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
