Question about Lenovo ThinkPad T61 Notebook
T61 Screen Problem
A faint line appears down the middle of my screen. Does anyone know if this means my screen has been damaged (and if so, how can it be fixed) or can this be resolved by adjusting my desktop settings.
  • irishgeeze Apr 30, 2008
    Many thanks for your quick reply Mark. I'll try to adjust the brightness and contrast as you suggest. Failing that I think I can live with it until I get a replacement.
  • 472 Answers
If the line runs top to bottom and is perfectly straight then it is the panel beginning to fail.
The LCD that you see connects to a driver board behind it with a very fragile plastic ribbon strip. Any even slight damage to the connection on either side and you begin toget the problem you have.
It could have been caused by a few things.. Excess pressure opening the lid will cause it, as will closing the lid quickly too often.
Flexing the screen (opening the lid only using one hand on one side).
As you see it's more a pressure related issue then anything.
The normal "repair" is to replace the screen. To have the original driver tabs corrected can be a very expensive exercise.
If the line is feint enough, then adjusting the brightness and contrast may make it useable long enough until it is retired or a replacement screen can be found.
Posted on Apr 30, 2008
  • Peter Thompson
    Peter Thompson Apr 30, 2008
    I could mention a little auction site beginning with E and ending in Bay where you may be able to pick up another laptop with a dead motherboard you could salvage the screen from as well as other spare parts from it of course. =)
    Just do a search on that site for my favorite words.. Faulty, Not working, damaged etc in the laptop section.
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
Mar 01, 2018 | Philips FTR9955-17 DTV Receiver
I have a brand new 1day old 60inch sharp aquos led tv since we hooked it up it has had a faint greenish line going vertically right in the middle of the screen. nothing makes it go away. do you know what...
This greenish line is due to physical screen damage. This is not repairable and not your fault.
If you didn't drop this tv, then the TV was damaged in the box.
Return your TV to the store you bought it as soon as possible. The longer you wait, the more chance they'll tell you that you damaged the TV and that they're not responsible for customer's physical damage.
Mar 11, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Very horizontal faint white lines running down the screen
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 would get a Blue screen...check if the lines appear on this screen...if it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
Vertical line on screen Lenovo T61 Laptop
You have a dead column of pixels. The only solution I'm afraid is to replace the LCD screen.
I'm sorry the news isn't good but can you take a moment and rate the solution as fixya even if it wasn't what you wanted to hear? Thanks! :c)
Jan 19, 2009 | Lenovo ThinkPad T61 Notebook
Thick faint lines on screen
It sounds like it could be the cable. Does the same thing happen on all channels and all TV's?
Jan 06, 2009 | Norcent Technologies LT-3225 32 in. LCD...
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info
Jan 06, 2008 | Televison & Video
Lenovo ThinkPad T61 Notebook Logo
379 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
