Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool super cap. electric dryer imperial
Won't heat up.
    Genius:
  • 1,028 Answers
Element or thermal fuse at top of element housing most likely if either is bad ck vent system before using very long plugged vent can cause overheat long dry times and premature failure of element
Posted on May 01, 2008
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
What would cause no hot air when drying on a whirlpool imperial gas dryer ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Whirlpool Dryers
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer wont heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Aug 09, 2009 | Dryers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Imperial Series WGD5550SQ0 has low heat, does not start the way it used to. My wife has to alter the settings to make it work. What could be the problem?
The 'operating thermostat' is not working correctly. It should allow heating up to about 155 degrees F and then open for a short period and then re-close. This is the cycle during drying.
Jul 09, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De
