Question about Brother MFC 210C All-In-One InkJet Printer
Error message of "Unable to Initialize"
My Brother printer keeps beeping and telling me that it is "Unable to Initialize" and to refer to the user's manual for troubleshooting. It isn't a paper jam, the ink is full and was working fine and the cables are secure. I can't figure it out. Any ideas on this one?
Thanks
-Mich
  • 2 more comments
  • kentman1 Jun 10, 2008
    Thanks
  • Anonymous Dec 19, 2008
    I have the exact same problem.
  • smile_ile Dec 19, 2008
    I have the same problem. There are no paper jams, nothing stuck in it, and I unplugged it for awhile as they suggest in the user's manual. It's strange because I can still use some functions through the computer such as scan to file, computer fax. I just can't use any of the stand-alone functions or print. I recently installed all new Brother print cart then recieved a fax. Later that day it gave me the unable to initialize msg.
    If anyone can help me with this I'd appreciate it.
  • 71 TBird Mar 27, 2009
    I have the same problem. Called Brother and went over diagnostics
    with tech on phone. Came up with error 4F. He said there is
    a mechanical problem and I should have the unit serviced. The
    unit has seen very little use and seemed to develop this problem only
    after having the power turned off for a few days. Tried the
    purging solution suggested by someone here, but it didn't work.
    The purge list number on my printer was lower than 6,000. I'm
    still not convinced there's any mechanical problem; seems like a
    software problem. If anyone has found the solution to this vexing
    problem that so many people report having, I'd greatly appreciate
    hearing what it is. Thanks. Chas
5 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Posted on Nov 26, 2007
Mix-it-up
  • 832 Answers
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Posted on Mar 08, 2008
  • 537 Answers
SOURCE: I have a Brother DCP
Here ya go:
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_top.html?reg=eu&c=gb&lang=en&prod=dcp117c_eu
Select which type of manual(s) you want and then do your troubleshooting from there.
Mike
Posted on Apr 07, 2008
r434
Posted on May 06, 2008
unable to clean troubleshooting maintenance user guide
Posted on Jun 23, 2008
Shows print unable 4F
Brother MFC 5860CN - Error Print Unable 4F User manual
www.justanswer.com > Printers
Brother MFC 5860CN - Error "Print Unable 4F" User manual shows "Print Unable xx" = There is something stuck in the paper path. I have checked all visible ...
How to Clear the "Unable to Print" Message from the Brother ...
? 1:48
https://www.youtube.com/watch?v=BxbJbXf1u9w
Aug 2, 2013 - Uploaded by Brother Office
... to Clear the "Unable to Print" Message from the Brother PrinterDisplay ... please help me.. my printer ...
how to remove or solve error message "unable to print 4f" on ...
https://answers.yahoo.com/question/index?qid...
Jan 4, 2012 - An error appear on it's screen saying "Unable to Print 4F." I tried to ... that are not connected in the printer display because they are still clogged. DCP-J315W Brother Printer Problem ?
May 15, 2014
init unable 4f brother mfc-240c?
Jul 2, 2010
My Brother Multi-Function Printer MFC 5460 CN showed an error ...
Mar 17, 2008
More results from answers.yahoo.com
Dec 28, 2015 | Office Equipment & Supplies
My printer is asking me to refer to troubleshooting and the routine maintanence chapter in users manuel for - print unable 36 Does anyone know how I go about fixing this? Nikki
Check for a paper jam. I just encountered this same error on my Brother MFC-290C, and that was the cause. I had to unplug the printer's power cable to clear the error message.
Sep 02, 2010 | Brother Office Equipment & Supplies
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Trouble shooting and routine maintenance
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Initialize Error
1. reset absorbers counter
2. if #1 does'nt work, see for mechanical problems...
If you're never disassembly your printer - call service...
Nov 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP-110C printer/copy/scan/photocapture
so please tell us, what does the display tell you? Is it unable to clean? If so search for "unable to clean" or Error 46. This is explained a thousand of times here...
Mar 16, 2008 | Brother DCP-110C All-In-One InkJet Printer
Troubleshooting
So what error message does the machine display except mentioned one?
"Unable to..." and a two digit error code will help us more to understand the malfunktion of the machine
Feb 17, 2008 | Brother Multi-Function Center MFC-240C...
Will not initialize
Take it back to the dealer! Better do not fix that problem by opening the printer! If it is a second hand printer, write again here.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
179 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
