Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Asking about air conditioners
Is electrolux split ac with0.75ton the best?
  • 828 Answers
Http://www.electrolux.com.au/node37.aspx?categoryid=5514
There are many manufacturers out there in the market place. Electrolux is one of the respected name brands. I personally own a few of there products and have been satisfied.
Posted on May 27, 2008
Electrolux ac fault f6
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need anything else air conditioning related don't be afraid to check us out our AC Service and information online
Sep 03, 2016 | Electrolux Heating & Cooling
Solution for f6 code in voltas split ac
Indoor unit fan motor is defective - good luck
Read more: Voltas saplit ac not working error c ode in display f6? - F6 error code in split voltas air conditioners :: Ask Me Fast at http://www.askmefast.com/Voltas_saplit_ac_not_working_error_c_ode_in_display_f6-qna8442437.html
Jun 05, 2016 | Heating & Cooling
Electrolux split A.C. display F6 error and trips immediately after starting the compressor.
Anti high temperature protection.
Check the outdoor coil for airflow obstructions.
Check the outdoor fan motor for correct operation.
May 23, 2016 | Electrolux Heating & Cooling
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Error code h6 my ac split electrulux?
H6 indoor unit fan stall.
Most likely a faulty fan motor but could be a faulty controller board. My money is on the fan motor which is a DC motor.
Apr 24, 2014 | Electrolux E23CS75SS Air Conditioner
Error f2 in electrolux split ac
I'm not sure if all electrolux share the same error code table but most manufacturers have a common error report table for all of their own models. If that is the case, F2 is a indoor pipe sensor thermistor short/open fault. These are cheap and easily replaced.
If you have a multimeter, you can test the resistance of the pipe thermistor by disconnecting from the controller board and testing across the connector terminals of the thermistor wires. Resistance values are in the table attached.
You may have to get the service manual to be certain.
Apr 29, 2013 | Electrolux Heating & Cooling
We have electrolux ac 1.5 ton i n our ac display showing F8 it is not change in remote how remove that.
Jun 17, 2011 | Electrolux Heating & Cooling
WHICH IS BEST A/C NOW
Check out this site. you will get an idea about the types of AC so that you can buy it according to your choice.
http://www.hellogiri.com/home-air-conditioner-split-ac-window-ac-price-details-in-india-best-cost/
thanks for rating Good luck
Jan 12, 2011 | Heating & Cooling
Whmich is the best Split AC that is cost effect and efficient.
Any air conditioner with 3 Star ranged. is economical and also efficient.
Jan 03, 2011 | NewAir ACS-1200H Split System Air...
I have relocated so I want to shift my split ac from old to new place,in pune.What is the exact charge?
Look on the data plate on the outdoor unit it will tell you the exact charge from the factory.
If you have not cut it loose yet there is a way to pump it down so all the Freon is kept in the condenser. Let me know and I will tell you how?
Nov 25, 2010 | Electrolux Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
157 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
