Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Dishwaster Viking VUD141
When I trun on the dishwasher, all I heard is the humming sound. I checked the power and resetted the circuit braker as well. But still same problem. It was working last week>
Pls help
  • ckav8r Nov 21, 2008
    My machine will work great for 2 to 3 months. Then the bottom float switch will activate and the machine will not fill. I sponge out the bottom and it works fine again. The leak seems to be the drain from the door to the lower pan. What would caause this? The sponge foam (noise insulation) on the inside of the metal cover is also wet. Any ideas?
The floatswich down the bottom tray has aktiwated there must be a leak,(.water in the tray)
whether, upper conection nut between chamber and hose circulationpump .I had tha problem.
Greetings Frank
from Germany
Posted on Nov 08, 2008
THERE ARE NO CLOGS ANYWHERE IN THIS DISHWASHER VUD141-SS. EVERY AREA HAS BEEN CHECKED FOR POSSIBLE FOR CLOGS. DISHES ARE CLEAN AND THE WATER CYCLES FINE. HOWEVER WHEN THE TIMER REACHES THE CYCLE WHERE THE...
yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Feb 11, 2015 | Viking Dishwashers
Viking dishwasher parts
Yes, please type in " viking dishwasher parts diagram" into your computer, and you will see whatever you need!
Be blessed.
Feb 23, 2013 | Viking 24 in. Professional Series VUD141...
I need a power supply for a Viking 24 in. Professional Series VUD141 and where does the water hook up at on the unit? Where can I get the Power Cord for this?
any appliance store/shop can sell a power cord for your unit. the water hooks up front but you'll need an original water supply line due to the shape and fitting.
Jan 22, 2011 | Viking 24 in. Professional Series VUD141...
How do I find the door lock and a door seal (bottom of door) for my Viking VUD141 ?
Don't know about the lock, but the bottom seal for the VUD141 is part # PD100091 (just had mine replaced).
Mar 20, 2010 | Viking 24 in. Professional Series VUD141...
My Viking Professional VUD 141 DISHWASHER will not pump water through the spray arms
I have a viking VUD140 and there is no power cord. Can someone tell me where the power supply is suppose to go.
Dec 30, 2009 | Viking 24 in. Professional Series VUD141...
Pump will not stop pumping
It may be in "delime mode" check the manual.
If not the timer is likely at fault.
Dec 24, 2009 | Viking 24 in. Professional Series VUD141...
Viking vud141 - timer does not end the cycle
you can try this number 305-418-0010 they have everythin for viking product and very cheap
Dec 09, 2007 | Viking 24 in. Professional Series VUD141...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
244 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
