Question about Plantronics Explorer 350 Wireless Headset
Bluetooth headset stopped connecting - Plantronics Explorer 350 Wireless Headset
  • Anonymous Jun 01, 2008
    All of a sudden it stopped connecting. I tried to removing it as a recognizable device form my phone and repairing it but it won't do that either. I can't even seem to power it off? DO I have to buy another Bluetooth?
  • 906 Answers
Link
Please try above link.
Thank you
Posted on Jul 29, 2010
Bluetooth conecton faild
You need a new one, the batteries only last a couple of years.
Apr 17, 2012 | Jabra BT3030 Bluetooth Headset
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    How do i connect this headset
    Pairing the Headset
    Pairing is a process of associating Bluetooth devices with each other.
    It will establish a permanent security link between the devices and
    enable quick access to the services provided without the need to reenter
    Pass Keys. You will only need to pair your PS3 and the Headset
    once.
    Paired devices remain paired even when:
    -One of the devices is powered off.
    -A service connection is interrupted or stopped.
    -One or both devices are restarted.
    Mar 13, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
    I get the bluetooth symbol on the Nokia E63 handset but unable to receive calls.
    are you using a bluetooth headset? if yes then check whether u have switched on your bluetooth headset & also your phone & bluetooth headset must be reachable, that is, both should be within range as mentioned in your bluetooth headset manual.
    Oct 28, 2009 | Nokia E63 Cell Phone
    I need help pairing my motorola h500 to motorola i580 phone
    1. Make sure your phone's bluetooth is on.
    2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
    3. Scroll to power then press change.
    4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
    5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
    6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
    7. Select Motorola H500.
    8. Press OK or YES to pair the headset with your phone.
    9. Enter the passkey 0000.
    10. Press OK.
    Oct 08, 2009 | Motorola Mobility H500 Headset
    Connecting bluetooth head set
    >Paraphrasing from the manual:
    >1. Turn off headset.
    >2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
    >3. Set your 'phone to discover bluetooth devices.
    >4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
    >5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
    Mar 11, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
    Can't get my bluetooth to work with my phone anymore.
    1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
    3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
    4.Select BT350 once a connection is detected.
    5.The passkey "0000" is now entered to confirm the connection has been made.
    6.The cell phone screen will now read "Bluetooth Connection".
    Tips:
    1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
    2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
    3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
    please give good rating if the solution works.
    Thanks for using FixYa.
    Dec 31, 2008 | Jabra BT350 Bluetooth Headset Headset
    How do I set my Bluetooth Headset HBM-730 to discover mode?
    4.Select HBM-730 once a connection is detected.
    Tips:
    Apr 20, 2008 | LG HBM 730 Bluetooth Headset Wireless...
    Plantronics Explorer 350 Wireless Headset Logo
    53 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
