The dryer runs but there is no heat ..
The manual says it could be one of the two house fuses in the unit. My question is where are they located .
I have the same dryer that is about five weeks old and the heater element went bad or thats what the repair person had told me. still waiting for parts to come in. still under warranty. As the fuse goes it's your circuit breaker(s) if you have or what should be used a combined breaker which will trip both circuits at the same time. The fuses are not inside this unit or not like older dryers which did have internal fuses (some models) You can go to frigidaires wesite and download the service/repair manuals in PDF form.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
dryer works at my brother in laws house but not drying here. He changed outlet and cord.
I have the same problem. I believe the fuses the manual refers to are you house fuses. If one leg of the 240 VAC power is out, the motor could run but the dryer would not produce heat.
I'm trying to figure out how to get into the unit with out making a mess of it. I'm guessing it's either the heating element, the high limit thermostat or the heater relay. The problem is figuring out where these parts live in the machine so I can test them.
couldn't find the fuses. where are they located at.
