Question about Sony KP-46WT510 46" Rear Projection HDTV
Standby light tv wont go on standby light blinks 9 times
  • bahor Oct 08, 2008
    KP46wt520 My tv standby light blinks 9 times. Sometimes it turns on, sometimes it doesnt. hit or miss.... Wont turn on at all anymore, any repair tips? I think it may be switch, b/c when it did turn on it took for ever to here the click (power up).
    President:
  • 2,712 Answers
This is most likely due to 2 problems -Temperature or a bust capacitor,
1. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
2. You can also try this..if you unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
3. If you want to go in for a long term solution, you can easily replace the whole power board (should be about $20 or so), or just change the faulty capacitors. You can make out which are faulty, because their caps will be swollen on top. Here's a pic
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you.
PS. The capacitors are usually 680 - 1000 micro farad and 35V. however, if you dont find 35V, you could use a 50V as well. They will be slightly larger, but you should be able to get them to fit in.
You can buy the capacitors online from HERE or HERE if you wish..They cost $0.068 - $0.85 each, depending upon the model.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
Standby light blinking 9 times. tv wont come on.
2 Diodes was Replaced.
D6301and D6116 Set works fine
High leakage in D6301.
Problem solved. TV works fine.
What did you fine for this Problem?
Sep 27, 2010 | Sony KP-51WS520 51" Rear Projection...
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
Apr 17, 2010 | Sony KP-51WS520 51" Rear Projection...
Standby light blinks 9 times tv will not come on
standby light blinks 9 times and tv will not come on
Mar 07, 2010 | Sony Grand WEGA KDP-51WS550 51" Rear...
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Standby LED blinks 9 times; TV does not come on
An easy problem for a Sony authorized service center anybody else they may not have a clue.
Mar 27, 2009 | Sony KV-36FS16 36" TV
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Standby Light blinks
it is an error code of the sony maybe there is a problem in it.
Apr 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Fix my tv
please contact ur dealer
Mar 11, 2008 | Sony KV-32S42 32" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
