Question about Dell Inspiron 6400 Notebook
Replacing crashed drive on a Dell Inspiron 6400
Can anyone recommend a decent drive
Budget between 100 - 150
Original Drive SATA 100GB 5400RPM
  • ssco1774 Apr 30, 2008
    I have my invoice from this Dell machine
    It listed that it was shipped with a SATA drive - isn't that enough to prove that SATA is compatible. Dell is impossible to dela with on the phone
    If the original invoice shows the machine was shipped with a SATA drive - would that be enough to show compatibility
    I hesitate to call Dell
    Genius:
  • 3,587 Answers
Western digital..but make sure your Dell can handle the SATA compatibility
good place to start is here
support.dell.com
look for accessories.
Posted on Apr 30, 2008
  • Patrick Michaels
    Patrick Michaels Apr 30, 2008
    that's not my point..and yes, I deal with Dell all the time, since I do warranty repair in San Fran and Hawaii.
    what I'm saying is the replacement drive MUST be identical in SATA compatibility.
    western digital makes some good ones. maybe you'll consider one of their Green Drives?
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Trouble starting my DELL inspiron 6400. The start up screen appears and then everything turns black. I have tried to restart in safe mode but the screen is stuck on the "DRIVERS/isapnp.sys". Not...
Windows has crashed, some file required got corrupted. Your options are repair of the Windows or a clean install. Put the CD in and try to repair it, if that doesn't work you will need to do a clean install of Windows.
Dec 29, 2010 | Dell Inspiron 6400 Notebook
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
Oct 27, 2010 | Seagate Momentus 5400.3 - 40GB - 5400rpm -...
I have a Dell Inspiron 1545 and It is a just over a year old (by one month) and I have to replace the hard drive since its out of warranty. The drive is a Toshiba SATA 5400RPM 250GB Disk Drive. I have no...
I can understand the inconvenience you are going through. I have worked in dell so i would like to tell you that the hard would would cost you around $50. The sales rep will give you a costlier option but you can ask them for this price hard drive. If you get it from dell the rep in technical will also assist you in getting it installed free of charges.
I would say get it from dell either online or over the telephone..
hope it helps
Thanks and Regards
Anand Sachan
Oct 25, 2010 | Dell Inspiron 1545 Notebook
Have a dell inspiron e1505 that continually cycles through the start up process. when i hit f12 and run diagnostics iget 0142 and 0146. when I reinstall it will work for a few days and then crashes again....
The error messages indicate a failing hard drive. Replacing the hard drive will resolve the problem. 0F00-0142 amd 0F00-0146 are hard drive hardware failures, Dell Tech support should replace the hard drive if under warranty.
Dec 31, 2009 | Dell Inspiron 6400 Notebook
Hi I got a Dell Inspiron 6400 laptop. The current HHD is the seagate momentus 5400.3 120g. This is now damaged. Can I use the Seagate Momentus 5400.6, 320 G, 5400 RPM SATA2. Will my laptop support the 320g...
Hello: I see no problem using a bigger harddrive in the unit,the only concern I think you might have is to purchase a hard drive caddy for the interface, Especially if the current hard drive is an IDE Interface, You can purchase a IDE to Sata Interface caddy, to support the drive Interface if it's an IDE format. You might want to check with Dell for compatibility first before purchasing the Sata Drive.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
Upgrade-replace Dell inspiron 6400 laptop's hard drive ???
I'm sorry to say there is no Easy way to do this with a Laptop without re-loading everything from scratch. As far as using the old drive as an external, you will have to order an enclosure for it. Tigerdirect.com is one source so is Ebay.
Mar 21, 2009 | Dell Inspiron 6400 Notebook
Multiple Boot on a Dell Inspiron Laptop
Invest in a couple USB drives and install the other os's on them. before you boot up plug in the apropriate drive and boot from it. Thats less complicated and painful to me
please, Let me know :)
Dec 24, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1150
2 - 1GB RAM modules. Best place to buy, Crucial.com
http://www.crucial.com/store/listparts.aspx?model=Inspiron%201150
Guaranteed compatible lifetime warranty
As for the hard drive
Here is a decent deal on a 100GB HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822153029
Jul 13, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 6400 Notebook Logo
95 people viewed this question
Alun Cox
