Question about Jenn-Air JCB2280HES Side by Side Refrigerator
Jennair side-by-side Hello: My ice maker won't make ice and the freezer and refrigertor is not as cold as it has been. Thanks
  • powelldesign Aug 09, 2008
    I've turned the dials up to 7 on both refrig and freezer
    Scholar:
  • 58 Answers
Clean the coils
Posted on Apr 30, 2008
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Jan 23, 2014 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Jennair jcb2058gew. Freezer is working fine but the ice maker is not getting water. Cold water dispenser in the fridge works fine.
this is the water valve .. its a dual valve one side for the isce and the other for the foutain .. repl valve this should correct problem mm .. hope this helps feed back pls ..
Jul 09, 2011 | Refrigerators
We have a Kenmore Elite refrigertor. The ice
hi,please remove ice maker see if an ice is jamming it up first...second on the freezer ,when you open it up...is there a switch on the wall..that is a infrared for the icemaker,,if so switch it off...remove ice maker...check it first....if its ok...possible problem with sensor...check these things,,,is filter ok...is water coming out of door,dispenser...then filter ok....good luck call if need assistance,,,michael,,doctor airr appl.repair..843-384-8474...
Mar 28, 2010 | Refrigerators
My refrigerator is not cold enough.
I had this repaired by replacing the motor-fan in the refrigertor behind the air deflector which sends the air from the freezer to frig. hope this helps. The motor was not working.
Aug 03, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
131 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
