Question about Tomtom GO 720 GPS Receiver
TomTom 720 does not TURN ON
I think It is all about charging. When the green LED is on TomTom should be charging. But quite often it isn't (even if green LED is on) as it is not shown on the batter status (should shown charging on the right top corner of the screen). So when the battery is empty it switches off. I tried to use car mount kit or stationa car kit. It worked only if I slightly pressed the unit to the Mount Kit. It must be sth with connection between unit and mount kit - i.e. conncection has many pins.
I think it can apply to many other users, when trying charging or reseting theri TomTom
  • 2 more comments
  • tomtimtamtom Jun 08, 2008
    Same here - on a tomtom 710. It started after a rough ride on a dirt road. The shaking must have worn out some plastics near the connector.
    If I mount it just off the dashboard, and push something to TILT it clockwise, the charging resumes.. If it just hangs in the mount it does not charge anymore
    So it looks like the tomtom 710 has two power-pins, one for charging and one for powering the device? (because it can work without charging the battery).
    Anyways if anybody can post a solution without replacing either the tomtom or the mount (not sure what is worn yet), I would be really grateful.
    Regards
    Tom
  • laidoffsick Jul 18, 2008
    Won't turn on. Hit the reset, and it starts to play music and then freezes on the display pic. Then it won't turn off. Happens on battery mode and on ac mode. Was workin fine, but now it don't turn on.
  • modtomtom Oct 26, 2008
    mine takes between 20 - 40 minutes of turning on then resetteing it cos it shows the tomtom in its cradle with the harddrive in the bottom corner, after 2 minms a circle appears showing its not worlking, after i reset it many times it finally works, can anybody help me as i use it daily and am getting woud up with having to wait for it to work.
  • jcaptchaos2 Feb 18, 2009
    I have a green light when in the docking station, charged it overnight but won't still won't power up
Have you guys tried cleaning the pins with some contact cleaner or alhcihol
Posted on Jul 05, 2008
It isn't heat related, mine is doing the same thing as is my Dad's. I have used mine in the heat, but my Dad's hasn't been used in about a month. I think it has to do with the last software update. That is when my problems started
Posted on Aug 30, 2008
I have had problems with my TomTom720.
First for the past 2 weeks it turns itself back on after I turn it off... sometimes I have to turn it off 2-3Xs until it finally shuts down.
Now... it just quit working. It won't turn on at all.
I have a sneaking suspicion that it might be heat related. It has been over 100 (in the car over 110) and I think the heat may mess with it.
Posted on Jul 08, 2008
My satnav tomtom go 720 wont turn on
either voltage overload or faulty usb socket.
www.compu-sat.co.uk
Jun 13, 2014 | Tomtom GO 720 GPS Receiver
It keeps freezing and battery wont charge
Usually when the battery doesn't hold a charge anymore (even if you've plugged it in to a power source for quite a long time), the device will not longer work ... i.e. it freezes or shuts down. That's because the GPS uses power from the battery and not from the AC power source (that is plugged in and charging the device).
Replacing the battery may bring it back to life ...
Aug 26, 2013 | Tomtom GO 720 GPS Receiver
Tomtom 720 won't turn on. Its charging as i type this as am not sure how flat it is. But..... Q1. Left it on charge on laptop for about 45 mins and it started to install Tomtom home. Windows Vista then...
Remove the SD card and try to connect to your computer, the 720 maps are in the internal memory and the unit should start. If not try a hard Reset through the "Reset"hole in the case of the GPS. insert a small paper clip to reset the GPS.
Feb 15, 2010 | Tomtom GO 720 GPS Receiver
I HAVE A TOM TOM GO 720 I SWITCH IT ON NO PROBLEM BUT WITHIN 30 SECONDS BATTERY WITH A YELLOW I IN A TRIANGLE COMES UP AND GOES OFF
The GO 720 charges quite slowly when attached to the in-vehicle cigarette lighter cord. If you have a USB attachment (that allows you to connect the GO720 to your computer) just insert the GO720 into the USB cradle - you don't have to turn it on - and let it sit there for about 10 hours. You should see the green light on the GO720 indicating that power is being received. In fact, I don't think you even need to turn on the computer, as power is always fed to the USB circuit. If you see the green light, then the GO720 is being charged. I think your GPS just needs a good charge.
Nov 22, 2009 | Tomtom GO 720 GPS Receiver
My tomtom doesn't turn on
the green light shows when i am charging my tomtom but it doesn't turn on.
Aug 19, 2009 | Tomtom GO 720 GPS Receiver
The battery gets shot to quickly !!!
depends on what all options are you using are you transmitting to your stereo using the bluetooth options the battery life is not to long mabe 1-1.5 hours
Dec 24, 2008 | Tomtom GO 720 GPS Receiver
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
TomTom Go720 shuts off spontaneously
tomtom GO-720 will not power back on after leaving on top of refrig off for the past two days now?
May 17, 2008 | Tomtom GO 720 GPS Receiver
Tom Tom Go 720
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 15, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
2,771 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
