Question about HP OfficeJet 7410 All-In-One InkJet Printer
Color cartridge problem
I have replaced the color cartridge now with 2 new ones and still get a 'remove and check color cartridge' error.  I ran the self test report and the blue line is not full (although the cartridge is new).  The green has a yellow bar at the end of it and the violet has a magenta bar at the end of it.  I have cleaned the heads......HELP!!!!!
  • Anonymous May 03, 2008
    Replaced the ink cartridge and turned off the printer
    Scholar:
  • 87 Answers
Check the color side of the carriage....there is a metal piece in there that breaks free from the side and will "stab" the circuitry board that the cartridge comes in contact with...you will probably see a hole in it...I have replaced several print carriages...fairly common problem with all of the HP printers that use the 96 and 97 cartridges...hope this helps
Posted on May 21, 2008
  • 1,031 Answers
This may be a printer failure.if the ink catridge is not refilled you
change the print head for improvement
Posted on May 14, 2008
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
I LOADED NEW CARTRIDGES AND RAN THE ALINGMENT, EVERYTHING SEEMED FINE hOWEVER, WHEN I WENT TO PRINT IT WAS NOT PRINTING CORRECTLY MISSING LARGE PLACES, ETC. THEN IT READ ERROR MESSAGE 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. looking from the contact side for the color cartridhe 2nd row contact 2 from the left. . I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape.
~jash
Sep 06, 2011 | Dell 962 Photo All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Message in LED is ''Remove and check color cartridge''
It means that the printer has detected a problem with the color cartridge. If it holds multicolors one could be empty & the cartridge must be replaced in order for it to work. Best advice would be to try a new cartridge and see if the error message goes away. Hope this helps.
Mar 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
This is not a joke! I've owned 3 premier HP ink-jet printers and each one broke under extremely suspicious circumstances. They provide a very limited amount of use time, and their cartridges are severely OVERPRICED!
I believe that anyone reading this should look at their HP, and replace it with a "Brother", "Lexmark", "Kodak", or other reputable company that provides a "DURIBLE" product.
HP is a huge brand name, and they have established themselves for their ease of use. But a printer is not a pair of shoes that should be changed every year or 2. They are poorly constructed, and they get back every penny you save on them by overcharging on the ink.
HP should PAY for betraying their costumers trust, and simply "Lose" their customers! Kodak is better anyways! HP is a second rate product with first rate "BRAND RECOGNITION".
Jun 23, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
124 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
