SOURCE: Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
SOURCE: vonage and faxes
Only real solution I know would be to get rid of Vonage. All experiences with Vonage has left a bad taste in my mouth. Regardless of your broadband speed, Vonage uses open internet and is subject to network problems. Fax's require Real-Time communication/transmission control, which is, thus far, not available with Vonage.
SOURCE: HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
Have you checked with your service provider about sending fax from VOIP lines.
Because iam affraid HP does not support VOIP Services.
Even if you call HP Tech Support they will ask you to call your VOIP Service provider they should have a answer for that.
Because the HP Fax machine only supports Analog signals and the VOIP Services have Digital Siganls which the machine cannot recognise, So please contact your VOIP Services for the same to send send faxes because it is not the fax machine which cannot send fax it is your VOIP Service provider which has a problem.
Good Luck
SOURCE: unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
