Connected Emotiva mps1 power amp to Onkyo 875 and cannot control volume with master volume control knob, although can do so with Harmony controler.
  • nolivivit May 01, 2008
    havve previously connected 7 preout cables from Onkyo to 7 inputs to Emotiva without success. The Onkyo does have multichannel preouts. so that it supposedly can be used as a preprocessor. Best, Emmanuel.
  • nolivivit May 02, 2008
    There are actually eight preouts on the Onkyo and seven of these are attached to the seven input channels of the Emotiva and it sounds great, but I just cannot control the volumes with the master volume control. When the Onkyo is used srictly as a receiver without any conection to the Emotiva, the master volume control functions normally. What I don't understand is how the Harmony controller can control the volume when the Onkyo is used as a preprocessor. Thanks for your thoughts and advice. Emmanuel.
  • 4,234 Answers
In order for this to work as you expect, you must connect the amp to a pre-amp out jack on the receiver. I don't think that the 875 has that option. If you are connected to the tape out, that is a fixed line level output that by passes the volume control.
Dan
Posted on May 01, 2008
    Genius:
  • 1,447 Answers
What cable are you using to connect MPS1 amp to Onkyo?
  • 1 more comment
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 01, 2008
    If you want to connect amplifier anduse the AV receiver solely as a preamp, connect the ampto the PRE OUT jacks, and connect all speakers and the subwoofer to the power amplifier. If you have a powered
    subwoofer, connect it to the AV receiver’s PRE OUT
    SUBWOOFER jack.
    On the menu setup activate zone 3. heres the link for the manual
    MANUAL
    Check this as well
    • Speaker cables may have come undone. Turn off your system and check the cables, and tighten the amplifier and speaker binding posts.
    • Damaged audio cable.
    • The preamplifier volume level is low for the channels concerned. Recheck the preamplifier calibration procedure.
    • A preamplifier Mute switch may be on, or an external processor loop or a tape monitor loop is engaged.
    • Check that your preamplifier or source is running the correct surround sound mode. Maybe it is set for 2-channel stereo when you were expecting 5.1 surround sound.
    • Check in case any missing channels have been turned off in a preamplifier setup menu. For example, the center amplifier channel will not receive a signal if the preamplifier has been set to “Phantom.”
    • The Auto/on/off switch on the MPS-1 might be in the off position.
    Here is the link for the amps manual: emotiva
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • Maanita Chadha
    Maanita Chadha May 01, 2008
    Do a hard reset to the system, shut the power down leave it turned off for an hour this will remove all the static power from the components and then the master volume control can be used in a normal state.
The volume control only goes up to +18 on my onkyo t sv919thx. can't hear it
Sounds like the volume controller is faulty. Did you use the master volume knob on the front to increase the power rather than the remote?
Here is your manual. It sure is a complicated piece of kit. They have three service centres on the last page.
https://www.de.onkyo.com/downloads/2/6/5/5/3/Manual_TX-SV919THX_En.pdf
Dec 30, 2016 | Onkyo Audio Players & Recorders
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
The recommended settings for a mofet car amp 50.4 , theres a few knobs not sure what they should be turned to
The gain knob is used to control how much the volume (output) of the amp increases with each increase in volume on the deck (installed in the dash). This is used to match speakers running of your deck. Other knobs are probably for a crossover (labelled in Hz). This controls what frequencies are passed to the speakers connected to the amp. A Highpass (HPF) crossover passes all frequencies above what the knob is set for. A Lowpass (LPF) pass all frequencies below what the knob is set for. A HPF is typically used when the amp is powering component or full range speakers to keep the ultra low frequencies (anything below 90Hz) from going to theses speakers. A LPF is used when the amp is connected to a sub. Subs dont handle higher frequencies very well.
Nov 02, 2013 | Crossfire Car Audio & Video
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
My harmony 520 is set to control the onkyo receivers volume but changes the volume on the tv.
Learn the volume commands for your TV and Receivers. This will resolve your issue. Please see the link below.
Learning in RAW--
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Jan 07, 2010 | Logitech Harmony 520 LCD Remote Control
Mitsubishi M-VR900 remote
Harmony by Logitech; they have models ranging from 70-400 based on your needs. They are 100% programmable, meaning any function your unit has, it will duplicate. PC software is very user friendly. You can set this remote to control up to 14 different devices and one button control. They even pass the Wife/Mother, & in-Law tests.. They have a substantial Database of products on file so you don't have to have your original remote. If you have problems while programming, they will actually answer their phones 14 hours a day. Why do I like these so much? Price/Performance/User friendly & I program all remotes from Universal to Crestron. Hope this helps. If you have any questions, reply & I will answer for you & help any way I can.
May 25, 2009 | Mitsubishi M-VR900 Receiver
I have a Bose Accumass 6 system connected to an Onkyo amp running as a entertainment system on our boat. The quality is sufficient for what we need. The amp (a TX-DX575) has A&B speaker switches for a...
two 8 ohm speakers in parallel is 4 ohms.
if series 16 ohms.a high resistance will just produce less power.
too low a number can activate the speaker protect,or blow the amp.
radio shack sell wall mounted speaker controls,but 5 watt max.
the best thing is to run 2 amplifiers.one for in ,2 for out
speaker a and b on the amp parallel the speakers.
if you run 2 sets of 4ohm speakers,the amplifier load will be 2 ohms,and overheat the amp.4 8 ohm speakers,gives a 4 ohm load
May 09, 2009 | Onkyo TX-DS575 Receiver
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
77 people viewed this question
 Grubhead
Grubhead
