Question about Philips Audio Players & Recorders
Phillips HTS3555 Surround Sound system. Cannot get the setup menu on the TV. Only one speaker is producing sound - the left front speaker. Followed step by step instructions w/out success.
Not sure as a friend did it. Thanks anyway.
Posted on May 01, 2008
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
My mom just bought this philips sound system and the subwoofer is not producing any sound. The other speakers work just fine but the sub woofer does not work. I was wondering if their was any call backs or...
Press the surround button on the Philips remote to see if the subwoofer will begin producing noise - the surround button switches the mode from simple stereo to full surround. I would test the surround button while watching a DVD, because not every tv channel is going to even produce surround effects. Good luck!
-Tha Mp3 Doctor
Dec 18, 2008 | Philips HTS3450 System
Onkyo HT-SR800 the surround speakers are not blasting
I had the same problem and fixed it by manually setting the surround speakers changing the Level Cal to +12dB. You will immediately notice a significant increase in volume and may need to back down on the dB's. What a diffence it makes!
Sep 14, 2008 | Onkyo HT-SR800 System
No sound...no... it is not the mute button
Did the TV produce sound along with the surround system in the past?
Verify the audio is connected through the TV and not directly to the surround system.
Usually there is an option in the TV setup to disable the internal speakers if the TV has variable audio output or audio pass-through. In Sony TV's this is usually one of the later menus and the option turns the TV speakers on or off, but it depends on the make/model of TV.
Apr 06, 2008 | Philips 32PF5320A 32 in. LCD Television
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
122 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
