Question about Xerox Phaser 8500/DN Printer
Xerox 8550/DN Printing with usb problem.
I have a very strange problem with my Xerox 8550/DN. When i print from the printers panel everything is ok but when i try to print from my computer a photo or a letter the page comes out fazzy.
    President:
  • 2,072 Answers
I will offer some thoughts.
But thats weird .
Have you tried a new driver? Yeah I know, that doesn't make a lot of sense to me if the image is fuzzy, but since it will print a internal pattern clear and not a print sent from the computer, the driver may be the issue. I stress MAY be the issue.
What I suspect more is the drum encoder. When I hear about that machine bluring, that is the most likely cause. It picks up silicon lubricant from the maintenance kit and normally causes blurrs.
It is on the right side of the machine ( viewed from the front), track it from the drum shaft. It has a clear plastic cover over it, but it needs to be cleaned with alcohol to disipate the silicon lubricant from it.
No no not drinking alcohol, although that can make prints blurry LOL.. Hope you have a sense of humor. To many people today don't....................
Posted on Apr 30, 2008
Error - unavailable: postscript initalizing
can you give a little more detail?
are you getting an error number? is this happening when you turn it on or send a file to it? try using another program and see if it stilldoes it
try updating your printer drivers, update the printers firmware
and see if it continues
May 03, 2015 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
Hope this helps.
Dec 25, 2010 | Xerox Phaser 8500/DN Printer
How do i get a network configuration page for a xerox phaser 3500
1. On the control panel, press the Menu button, then press the OK button to select
Information.
2. Select Info Pages, then press the OK button.
3. Select the appropriate information page, then press the OK button to print.
Note
Print the "Menu Map" to see other information pages available for printing.
Hope this helps
Kevin
Nov 10, 2010 | Xerox Phaser 3500/DN Laser Printer
Xerox 8550 DN display does not work and printer does not print
This model of printer has a known fault with the LCD panel.
Contact xerox in your country, who will arrange to have a replacement front panel sent out to you to install
Aug 03, 2009 | Xerox Phaser 8500/DN Printer
Printing Phaser 8550
that is a part of that printer design. Something sadly you can not get rid of. Believe me, I have tried, and Xerox engineering told me that is part of how the machine is supposed to work. Wish we could eliminate that.
Mar 26, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8550 Printer Magenta ink not working.
You need to run the eliminate light stripes. it should be in the menu, under troubleshooting, print quality issues. you can run this up to 3 times. you want the run the basic light stripes, not the advanced. If after 3 times running this, you are still missing jets, your printhead is bad. If you are using aftermarket ink, media sciences might cover the repair, if not, the printhead costs as much as a new machine. about $650+labor.
Mar 16, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 Pause
Go into Control panel, Open the Printers/View installed printers.
Right click on your printer, and remove the "Pause Printing" check mark.
Jan 19, 2009 | Xerox Phaser 8500/DN Printer
Dark streaks
You need to remove the maintanence kit and clean the wiper blades there and where the paper comes out of the machine at the top. See below and check when your maintenance kit runs out and how to replace it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=389,E=0000000001343282793,K=7185,Sxi=9,Case=obj(947)
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=389,E=0000000001343282793,K=7185,Sxi=9,Case=obj(1031)
Nov 03, 2008 | Xerox Phaser 8500/DN Printer
Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Oct 14, 2008 | Xerox Phaser 8500/DN Printer
The front panel shows nothing
When our control panel went blank last month, Xerox did not offer a free replacement because our printer was out of warranty. Consequently, we ordered one from SparePartsWarehouse.com at the best price we could find - $104.87 plus shipping. The part number for our 8550dp is 848K06551, but these are the compatible part numbers for the "Xerox 8500 Control Panel & Bezel": Compatible Part Numbers: 848K06551, 101E28730, 101E28731, 802K93650, 802K93651, 848K06550, 848K06552. It is easy to replace, instructions are on the Xerox website at http://www.office.xerox.com/printers/color-printers/phaser-8500-8550/sprt-enus.html
Hope this info helps someone, and thank you FixYa for this forum.
Aug 30, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
