I pluged my nanopod into my computer, but the computer is not "recognizing" that it is plugged in. My nanopod works otherwise. I plugged my i-pod into my computer, and the computer recognizes my ipod fine--it's just my nano taht I cannot get my computer to recognize.
  • 5 more comments
  • Poundie Apr 30, 2008
    I should note that I have Windows XP and a 1GB nano.Again, the nanopod works fine except that since my computer does not recognize it when it is plugged in, I thus cannot update it.
    I don't know, I just tried it on my own computer.
    I tried that already and it did not work. I should note that my ipod works fine, it is just my nano that has this problem (I never had this problem with it before today) which suggests that the problem is not with the computer or the cables.
    I just tried that, you had instructred. The probem is My Computer is not recognizing the nanopod t al. WHen I plug my ipod in, it shows up as a disc in the My Computer folder; when I plug m nanopod in, it does not. Thus when I did what you told me, the nanopodi not show up at all, so I could not find it (again when I put the ipod it, it was found right away) and thus I could not change its letter or paths.
    << left click on it > double left click on disk management > when you find the nanopod right click on it > left click on change letter and paths > click on change. Now you can change to the letter you want other than C. D or E, try Z fro example.
    Good Luck.>>
    I will try this and get back to you.
    >>>If the nanopod came with the driver, I would suggest to install the driver first and try again.>>
    I believe the driver for the nanopod was on the nanopod itself. Is there a way I can download a driver for it? But then again, if the driver was defective, shouldn't my computer recognize that a new unrecognized device was plugged into the USB port?
    >>>>If none of the suggestions work, you might have a defective device.
    How old is the nanopod?>>>
    The nanopod is about a year and a half old.
    I tried my nanaopod with another computer, and it still did not work (my ipod worked with the other computer, however). Clearly, something is wrong with my nanopod that prevents it from being recognized by the computers.
    I tried playing my nanopod (that works) and when I plug it into the USB port on the computer, it says "charging" so it seems to be connected to the maching somehow. But even after it finished charging, the computer is not acknowledging that the nanopod is plugged in.
    <<<If you dare to open it and check for a loose connection where the USB is.
    If you find a loose connection there, you will need to hand solder it.>>>
    I wouldn't know how to open it, nor do I have the tools. I suppose I would have to go to somebody who can fix nanopods; how much would it cost, do you suppose, or should I just buy a new one?
  • 813 Answers
Hi friend
change your data cable try to connect u have bad data cable so if u change the cable your problem will sloves
Posted on Apr 30, 2008
    Guru:
  • 1,894 Answers
Is that nano not recognizing any computer or ur computer alone?
  • 2,323 Answers
You will need to assign a different letter to the nanopod. Plug it in and follow the next steps:
Right click on my computer go down to manage > left click on it > double left click on disk management > when you find the nanopod right click on it > left click on change letter and paths > click on change. Now you can change to the letter you want other than C. D or E, try Z fro example.
Good Luck.
  • 2 more comments
  • Jaime Hernandez Apr 30, 2008
    I would suggest to try using a different computer just to isolate the problem to the nanopod.
    The device should be recognize once is plug into the USB port. The only time when the computer will not detect the new device is when there is not power circulating through the nanopod.
    The final conclusion is that the nanopod is defective.
    I would say that not many technicians might want to fix it, because the repair might cost you more than buying a new one.
    Good Luck.
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
Computer been pluged in for hour and willnt charge over half way what do i do?
The battery or the charger may be malfunctioning. Please verify that the computer recognizes that the power cord is plugged into the computer. There should be a plug icon over the battery in your lower right hand corner. If it doesn't show the plug icon, and the battery is draining your charger is likely bad. Otherwise your battery is more than likely going. If your model is several years old, I'm afraid to say that after constant (or even semi-constant) use the battery will die after 2-3 years and need to either be replaced or used less frequently.
Mar 02, 2011 | Acer Aspire 5050-3242 Notebook
When i connect my pen drive to the pc,it says "USB Device Not Recognized. One of the USB devices attached to this computer has malfunctioned and Windows does not recognize it"
please you can try a diferent usb port.
if that dont work, then shut down and resart your system with device plugged in.
if it still don't work, reinstall driver if device isn't plug and play
Jan 09, 2011 | Computers & Internet
External hard drive isn't recognized!
try pluging it into a different usb port try a different cable if they all do not work then the partision table has been damaged and the drive will have to be reformatted
Dec 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Not working
your camera device has a cd driver camed with you camera box. install it on your computer so that your camera will recognize it everytime you pluged it in. hope that helps
thank you for using fixya
CHARCOIS
Jan 19, 2009 | Polaroid i733LP Digital Camera
Creative Zen V Plus won't turn on, computer won't recognize.
hi there, what i did was push and hold the reset button for about 30 seconds and then vuala, it reset and still had all of my stuff on it. to the guy who the reset button didnt work you might want to try two or three times, otherwise i dont know what else there is to do but get a new one. well i hope this works for you guys.
Dec 01, 2008 | Creative Labs ZEN V Plus MP3 Player
My computer wont recognize my mp3 player
have you checked in "my computer"?
if you have then try resetting it in the back
hopefully that works
May 23, 2008 | Coby MP-C7085 MP3 Player
298 people viewed this question
 Grubhead
Grubhead
