Question about IBM NetVista PC Desktop
Video display driver
I have an IBM Netvista model 6792 and my screen is dark. i cannot seem to get the color red on it. I have blue, gray, etc. where can I update teh driver? i called IBm and since it si out of warranty it will cost $1000.
  • sajiseba14 Apr 30, 2008
    how do I move the cabels? do i open up the computer?
  • 472 Answers
It's not your driver. It's the video cable from the computer to the monitor.
Move it around at both ends and your colour will return to normal.
Either replace the cable or find where it is happy and then hold it in that position with something.
It's a common fault to all monitor cables..and nearly always the red wire.
Posted on Apr 30, 2008
  • Peter Thompson
    Peter Thompson Apr 30, 2008
    No, there will be a cable that will run from the back of your computer to the back of the monitor. There will only be one cable doing this unless you have your power for the monitor also connected to the both.
    The cable will have a solid looking connecter on it, and have 2 twist screws to hold it in place at each end. Just move the cable around without removing the twist screws.
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
VIDEO CONTROLLER drivers Multimedia audio controller drivers Ethernet controller drivers
Click the website below...scroll to the bottom and choose which model number you have. Click on the appropriate drivers. Best of luck to ya.
http://www.drivershq.com/drivers/ibm/NetVista/21347/23182/Models.aspx
Aug 20, 2010 | IBM NetVista PC Desktop
Will not power up when network cable attached
There is a Wake On LAN support on netvista 6792
and possibly this may be the reason
First, go into your BIOS, find the PnP hardware settings and disable Wake-on-LAN (it may be in a different category depending on your BIOS).
let me know if this has been perfrom
Jan 28, 2010 | IBM NetVista PC Desktop
I have a ibm netvista 8319 44g vista upgrade was recommended BUT i can not adjust screen resolution. I have tried lots of different fixes seems i need a new graphics card but what is compatable. i have a...
Hmm, have you gotten the latest video driver from the manufacturer?
Also, What resolution are you running? and what resolution do you need to reach?
More info on the PC like Video Card/Monitor Make and models would be valuable.
Thanks!
Jul 07, 2009 | IBM NetVista PC Desktop
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
Ibm netvista 6792-11u cannot display
Have you tried installing a different video card?
Thanks,
Lee
Jan 21, 2009 | IBM NetVista PC Desktop
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
IBM NetVista PC Desktop Logo
112 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
