Cable on hp pavilion 7800
I was replacing the power supply on my hp. Under the power supply was a cable plugged into the cd/dvd and then over into another part on the inside of the unit. Does anyone know what that cable would be called? The wires were broke out of the little black holders that actually plugged in to the dvd.
    Sergeant:
    Champion:
  • 271 Answers
If it is stripe cable about 3CM long it is the IDE cable (simply called it data cable)...other than that another smaller cable sometimes may be fixed without the power cable
Thats should is the audio cable...previous operating system (like 98) didn't recieve audio signals without that cable..but you dont need it now with XP..
The three cables are the POWER, IDE and the AUDIO
Posted on May 08, 2008
I put new power supply in my hp pavilion slimline but still wot turn on
the first thing you should do if it don't start is unplug everything (memory, cards - the lot) from the mobo apart from the power supply and turn it on.
if you get nothing, it's either the power supply or the mobo. check the power supply actually works, if not that then it's mobo.
if you get beeps, plug things in one at a time, when you arrive at the condition you started with, that's the bit that's wrong.
Mar 15, 2015 | HP Pavilion Slimline s5-1414 Core i3-2130...
How to get device manager to recognize SuperMulti DVD Burner? The player is installed (or was) and worked, but it suddenly vanished from device manager.
You should open the case and see if the power cable and sata cables are secured on the drive..... it is possible that the DVD drive control board has died. Considering there are many DVD burners out there for less than $20 the replacement should be cheap and simple.
Here's how to open and replace a CD/DVD drive from the HP site:
http://support.hp.com/us-en/product/HP-Pavilion-Elite-e9000-Desktop-PC-series/3999455/model/4007356/document/c01761233/
May 19, 2014 | HP Pavilion Elite e9260f (2531370) PC...
When I start up my HP Pavillion a6544f the monitor does not receive any signal and it remains blank. I have already tried to reset the BIOS and checked all loose cables and connections as suggested on the...
Yes, I have a LOT of information before you take it in for costly repair.
I believe you have a bad Power Supply. Weak voltage power rail.
How do I come to this conclusion?
1) Your Power Supply probably has enough power to light LED lights, and maybe spin fans, but it does NOT have enough power to turn the Processor on.
No Processor operating, No computer operating.
No computer = No Signal on the monitor. {No video signal}
A) ALL of the LED lights on at one time use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor uses 51 to 125 Watts of power. Depends on what Processor it is.
The HP Pavilion a6544f desktop computer comes with an Intel Core2 Quad Q6600,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01494006&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3757419
The Intel Core2 Quad Q6600 can use up to 105 Watts,
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors#Core_2_Quad
The Intel Core2 Quad Q6600 is a power hungry processor.
Solution?
Replace the Power Supply.
2) A bad Power Supply is one of the leading causes of computer failure.
Right behind it, is the computer is dirty inside.
(This also 'kills' Power Supply's)
The Power Supply has a Form Factor.
This refers to the size, and shape of the Power Supply's case, and the power cables coming out of the Power Supply.
The form factor for the Power Supply in an HP Pavilion a6544n is an ATX form factor.
It is a 300 Watt unit.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01324212&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3757419
The power cables needed are;
A) 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Color of the connector makes no difference)
B) 4-pin ATX + 12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) Uses a SATA harddrive, and a SATA optical drive, so the Power Supply needs to have at least two SATA power cables,
(Optical drive = CD/DVD drive. If there is more than one CD/DVD drive, there needs to be more SATA power cables)
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
To be continued in an additional Comment.
Dec 22, 2010 | HP Pavilion a6544f Desktop PC
I am looking for a hp lightscribe dvd supermulti drive/cd writer that is compatable with a hp pavilion a720n desk top computer and all so a dvd/cd rom combo that is compatable with ...
Any brand-new CD/DVD reader/writer with LightScribe *WILL* be compatible with your HP.
Check whether your "power" and "data" cables are the "old" style (white power connector and a 80-pin ribbon-cable) or the "new" style (thin SATA cables), before you buy a writer with the "wrong" (PATA versus SATA) interface.
Sep 26, 2010 | HP Pavilion A720N PC Desktop
No power to computer. Outlet is good. Power cord is good.
Try to do a power drain first by unplugging the piwer cable and then press and hold the power button for ten secs.after that plug the power button again then try to restart the machine.check for any indicators that the computer is getting power like sound coming offf the computer or if the cd/dvd drive is opening, check any lights on the tower or if the fan is running if not then you might need to have the computer checked.Power supply or the motherboard needs to be replaced.If the system is still under warranty then you can call your manufacturer for support.hope this helps...
May 20, 2010 | HP Pavilion a706n PC Desktop
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Jan 17, 2010 | HP Pavilion TX2000Z Notebook
My a730n will not turn on and the green led power light on the back is flashing
This indicates there is a problem with the Power Supply.
You have a weak voltage power rail.
Components inside the power supply have failed.
Most of the time this due to the power supply, as well as the inside of the computer is dirty.
The rest of the time it is due to a cheap quality power supply from the computer manufacturer.
You can be the best housekeeper in the world, but inevitably dust, dirt, and other material is drawn into your computer.
Your computer uses air to cool the hardware components inside.
Air is drawn in through the front of the Pavilion a730n, and is exhausted out of the back.
(There is one computer case fan in the back, and the Power Supply fan also helps)
This is the computer's Cooling System.
The cooling system for the Power Supply is a fan on the back of the unit, and Heatsinks that are inside.
(A Heatsink is a small plate of metal, with tall fins on it. The Heatsink works as a small radiator. Heat is absorbed up through the fins. Air is drawn through the fins, and heat is pushed away by the air)
When the fan blades, center hub, and surrounding cage become clogged with the above mentioned material, the cooling capacity drops tremendously.
Same thing for the Heatsink fins when they become clogged.
Heat = Wasted Energy
The Power Supply strains to keep up with the power load that is needed, and the additional loss of energy, (Power), that is lost due to heat.
Eventually components inside the Power Supply fail.
Commonly it is the Electrolytic Capacitors that fail first.
Computer manufacturer's commonly use cheap quality Power Supply's. They buy them from a Power Supply manufacturer.
Cheap quality = the computer manufacturer saving money, because the unit's cost them less.
1) Cheap Electrolytic Capacitors
2) Too small of a gauge of wiring is used
3) Cheap quality Rectifier Bridge
4) Cheap MOSFET's
The list goes on.
Solution is to replace the Power Supply.
Power Supply's come in many sizes, and power designations.
The HP Pavilion a730n uses the common size, and shape of Power Supply, used in 90 percent of personal computers. ATX
The power designation is 300 Watt.
Usually it is a Bestec, Delta, or HiPro power supply that is used.
C-H-E-A-P!
Based on personal experience, I would recommend this power supply for a replacement unit,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675269&CatId=1078
Not an advertisement for said website. You may find a better price by searching.
Know this:
A computer only uses the power it needs, and no more.
Example:
You could install a 1000 Watt power supply in your computer, (Not actually. It will not fit), and if your computer only needs 100 Watts,
it only uses 100 Watts.
(Typically surfing the internet uses 100 Watts. Same as a 100 Watt light bulb)
This is HP Support, Pavilion a730n, and the Manuals page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=431078&lang=en&
On this page you can download the Part Replacement Instructions manual.
Has large illustrations, to show how to replace parts inside the Pavilion a730n Desktop PC.
Power Supply replacement is shown.
From me:
If this is your first time in replacing a computer hardware component, this may seem like a daunting task. Once you are finished you'll realize it wasn't all that tough.
Inside your computer you'll see many cables, (Wires)
You'll see cables coming from the Power Supply, that go to the various hardware components inside.
(Motherboard, Harddrive, and CD/DVD drive/s)
Power cables from Power Supply
1) You have a cable with many wires in it. It has a white connector on the end, and is long in shape.
It has 24 socket holes.
It's a 24-pin ATX main power cable.
Connects to the motherboard. To release it from the motherboard, there is a lock tab on the side of the connector. Press the lock tab at the top. This pivots the lock tab, and draws a hooked end, out of the side of the motherboard connector.
Gently wiggle the connector side to side, while depressing the lock tab, ease it up.
(Side to side lengthwise)
2) You have 4-pin Peripheral power cables. (Also referred to as Molex)
White in color, 4 wires. (Red, Yellow, and two Black)
One to each CD/DVD drive you have.
3) You have One SATA power cable. Connects to the SATA Harddrive
4) You have One 4-pin ATX +12 power cable. The connector is square in shape.
Has two Yellow wires, and two Black wires.
This power cable is for power to your Intel Pentium 4 processor, and Must be plugged in.
Plugs into the motherboard.
This link shows the various power cables, and connectors, that I listed above.
(Large photos, and clear information)
(Scroll the page down, to view all of the power cable connectors. Click on a photo of a connector, to view more information about it)
Should you need more information, just click on Comment, and type it out. (Believe top right of your page)
Jan 12, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
Dvd/cd writer, and dvd rom drive does not work
Check if you have both cables attached to the CD/DVD drive. There are usually 2 that needs to be connected: the SATA or IDE (that ribbon-like connector that goes right to the motherboard), and the power supply (a connector that has 4 colored lines going to the power box). Make sure they are snug, and if necessary, try changing them with others that are known to work (there should be lots of spares). If the CD/DVD light blinks or powers on upon boot, it means power line is OK, but data cable connection is bad.
Sep 06, 2008 | HP Pavilion (PN153AAR) PC Desktop
HP Pavilion DVD drive replacement Vista
not too difficult
remove side panel of pavilion
tabs inside of chassis, near front of unit, press in gently. There are two or three of them
remove front panel from chassis
either remove the screws holding the dvd or use the green slider
unhook dvd from cables and power supply
slide out
reverse for installation
make sure you get new drivers from site(like this one) and resist temptation to use cd supplied
Mar 09, 2008 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
