Question about RCA HD52W59 HDTV Projection Television
Convergience Problem model number HD52w59 serial number f254c1080d i read that you could give the bad part # and location. Please get back to me. Slipknot0147@hotmail.com Amanda
    Genius:
  • 1,030 Answers
What part are u looking for
Posted on May 05, 2008
Need to know what year is my washer set
The date of manufacture is determined by the SERIAL NUMBER, not the model number. The serial number will be located on a nameplate (with the model number) along the wash tub rim under the lid.
The following link explains how to read the serial number to determine the age:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The 2nd digit in the serial number will identify the YEAR is was manufactured. The first two numbers, following that digit, will determine the WEEK (52 weeks in a year). This same information applies to all your other Whirlpool appliances.
If you have any questions, please post back and let me know. I hope this helps you.
Dec 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My kenmore dryer 70 series only blows out cold air now. it's not drying the clothes. is that the heating coil?
not always,next time send the model number,open the door and look around the opening of the dryer and you'll see a tag with the model and serial numbers,just need the model,it will start with 110. or similar,if the filter is on top then unplug the dryer and then slide out the dryer,remove the lint filter and the back panel and you'll find all the parts in the rear,if the filter is inside then all your parts are up front,also depending on the model number on some machines there's an even heat board and relays in the top console that can be bad but i don't think you have this,with a meter read out the heater,and all the thermostats on the heater box and check the thermal fuse located on the blower wheel housing,when checking any part you have to remove at least one of the wires or you won't get the right reading,when you find the part that's bad call your parts store,give them the model number,tell what part you found that was bad and they will sell you the correct part,good luck and let me know how you make out
Nov 15, 2010 | Dryers
What year is this model number?
Hi
You'll need the serial code to check for the year, the serial code is located on various locations. Please check this picture to search for your serial number--
After you find the serial number you can calculate the month and year of the washer by checking this coding list--
Code list for finding the year of manufacturing
Please post back for any further assistance.
Daniel
Jul 25, 2010 | Kenmore 98702 Stacked Washer/Dryer
What year was this dryer made
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains how you can determine the date on Whirlpool manufactured appliances:
Locate your serial number. It should be on a nameplate around the door opening, along with the model number.
The second DIGIT in the serial number represents the YEAR it was manufactured. The next two NUMBERS following that digit, represent the WEEK of the year it was manufactured (52 weeks in a year).
If you have questions about how to read your serial number, please post back and let me know. I hope this helps you.
Jun 08, 2010 | Whirlpool LEQ8000JQ Electric Dryer
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
Where's my serial number
You should provide a BRAND name in order to find a definite answer to this question. Different manufacturers place this information on nameplates in different locations on their appliances. Most commonly, the Model and Serial numbers are located around the oven door opening. You will have to open the door to see the nameplate. If you have a lower oven drawer, its probably located there. On certain models of Maytag and Fridgidaire (I'm sure there are other manufacturers as well) this same information is located on the BACK of the operator console. If you are still having problems, please post back with your brand name and I'll see if I can give you better guidance.
Nov 14, 2008 | Kitchen Ranges
I want to fix convergience myself....what or where do i go?
Go to the following link and leave a email with the model number of your set and what ist doing and they will respond quickly with the info you need they have any part you would need for your RCA and they give free tech support with their parts.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 46" (maybe) Monitor Broken What do I do?
If you registered the set with RCA you shouldnt need the reciept just call RCA and explain the problem and they can set you up with an authorized warranty repair center in your area. Heres the number for RCA support you will need your serial number handy when you call its located on the back with the model number.
580-634-0151
May 19, 2008 | RCA HD52W59 HDTV Projection Television
Tv will not power up
Flyback transfromer is bad,part number 259296,part is around 60.00,you might find it at mcm electronics,phone number is 1-800-543-4330
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Convergience
Hey Cancun,Ill be able to Answer this on Tech Support my Screename ttech
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
