Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
GARAGE DOOR OPENER
I HAVE A SEAR CHAIN DRIVEN GARAGE DOOR OPENER THAT RAISES THE DOOR TO HIGH. HOW DO I ADJUST THE OPENER
  • 1 more comment
  • ernieb10 Aug 05, 2008
    I have an old Sears Craftsman garage door opener - no longer have the manual. The door opens several inches too far and I need to adjust the travel.
    The only adjustment screws I can find are the open force and close force screws. I've tried to adjust the open force screw by several turns both ways but it does not seem to make any difference. Any suggestions?
  • woody22 Jan 20, 2009
    Sears Craftsman 139 655000
    This opener was left at my rental house not installed, I installed it and now it just wants to open and close and I can't find an adustment sensor to stop upon closing or opening. I have no manual. Please help.
  • Anonymous Mar 31, 2014
    trying to install a genie garage door opener a belt driven one and it will only go up and not down
    Champion:
  • 244 Answers
Depends on how old, OLD units need to take cover off and adjust cam stops. Not easy if you have not done before,
Posted on Jan 15, 2009
Refer to your owners manual to adjust the travel limits to stop the door opening too high
Posted on May 04, 2008
Cannot open my garage door manually after I disengage it from the garage door opener (chain drive)
They are not light weight but there is no reason if the motor can raise it, then you cannot raise it by hand.
Feb 05, 2016 | liftmaster chamberlain 1/2 hp chain drive...
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
My garage door sometimes gets stuck and then goes
Don't tighten the chain. It sounds like you have either a broken door spring or the drive gear in the motor unit is going bad. Release the opener from the door and operate it by hand. It should be easy enough to raise that your wife can do it with no problems and it should stay put when released about waist to shoulder high.
Jul 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Apr 01, 2010 | liftmaster Chamberlain Garage Door Opener...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door opener chain adjustment?
Remove the cover and check the main drive gear. It is most likely stripped.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage door opener does not go down to floor
I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
Just a suggestion, you might take a look.
just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener, chain adjustment
Loosen the inner nut on the trolley. (That is the lock nut). Then tighten the outer nut on the trolley to increase tension. The outer nut on the trolley is closest to the garage door. The chain tension should be 1/2 inch off the rail at midspan. (The chain is fastened to a threaded bolt on to the trolley. The threaded bolt has an inner and outer nut). Hope this helps.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
630 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
