Question about LaCie (300728U) 250 GB Hard Drive
LaCie 250Gb drive does not power up
The adaptor has a small green light that is illuminated when power is applied. If I then connect socket to drive the light goes out and the drive does not respond to pushing the blue button on the front. Is it dead. It is out of warranty and I'm handy with electronics. Do I need to operate on it?
Cheers
  • ADAICY Sep 15, 2008
    I used my Hard Drive the other day and it was fine, today i plugged it in and the power adapter illuminated green but the orange light on the front would not illuminate and i tried to unplug and plug back into the hard drive but will not turn on? Any ideas?
  • jay burke Dec 09, 2008
    the green light on my cable from outlet is on but light on drive does not light and computers do not read it being there. how do i solve this?
    i noted that a suggestion was to try another case. Where do i get another case. How do i purchase one or do i need to buy another similar drive. i have a design by  f a porsche an old one.
    (second problem is I know i need to re store my pics etc and somehow transfer them to a new drive. How?
No power no orange light
Posted on Mar 24, 2012
It's the power supply connection in the HD case has failed. Try the HD in another case (if you have one handy) to check whether this is the problem. If so, find a replacement case.
Posted on May 23, 2008
  • JudeGraySmit Jul 26, 2011
    I had a failure on my LaCie 250gb external hard drive . Went to bed one night unit was working. Switched all my PC and accessories off. Next morning NOTHING from the LaCie unit. No green or orange light appeared. I bought an IOMAX adaptor on Amazon for £17 to check if it was a power supply problem (as I read here it was likely).This saved me money as a new power unit was over £40. I dismantled the LaCie unit to expose the IDE hard drive inside, plugged in this adapter and it powered up immediatly. Selection of 'plugs' on this adapter as can be used on SATA, ATA, IDE and 2.5 and 3.5 sizes are covered. I have now used on all my old hard drives to transfer data once thought 'lost'.
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Low power problem?
There is a good chance that the problem is with the power adapter. I would suggest checking the connections and the adapter itself and the wires to make sure nothing is visibily damaged. I would also try connecting to another outlet.
Jan 18, 2008 | LaCie d2 DVD-RW Burner
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Power Adaptor for 500GB LaCie P3 HD USB 2.0 7200RPM 8MB USA?
Both power adaptors are 4 pin, ITHINK that the Porsche that you have is the same as mine which has the smaller (4 pin DIN) plug 34W power supply.
But check on LaCie's site: http://www.lacie.com/asia/products/product.htm?pid=10857
Hope this helps.
Chris
Jul 23, 2008 | LaCie Computers & Internet
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie (300728U) 250 GB Hard Drive Logo
349 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
