Rundll32.exe is an important process of your windows operating system.
The process rundll32.exe executes dll files and puts their libraries
into your system's memory. Without this process your computer would
become instable and very slow.
If a virus, such as the Netsky, destroys your rundll32.exe or, if
for some other reason, your rundll32.exe is corrupt or gets
accidentally removed, you need to take the following action:
Locate a Copy of Rundll32.exe on Your System
Check
if you find a copy of rundll32.exe in the folder
C:\windows\system32\dllcache or in C:\windows\ServicePackFiles\i386. If
this is the case, go ahead and copy rundll32.exe to the system folder
C:\windows\system32
First of All Run a System Repair Tool to Fix Rundll32.exe
There
are various tools available on the Internet that scan, analyze, and fix
your computer. Besides fixing your rundll32.exe, these tools will
remove any registry errors, remove invalid shortcuts and duplicate
files, repair DLL files, and remove startup and runtime errors.
A recomended tool is registry cleaner, it will fix your registry keys, defrage it and cleans the errors for you
TRY USING A PROGRAM CALLED ERROR REPAIR .IT SHOULD
SOLVE THIS PROBLEM.
SOURCE: ERROR IN COUNTER STRIKE GAME IN WINDOWS VISTA
before you run the game right click the icon that launches it and goto properties, goto compatibility tab, check the boxes run in compatibily with xp sp2 and check the box to run as administrator, click apply ok then run the program.
You have some viruses and malware.
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Start
programs below.
