I'm trying to resize the partition of my hdd, but the operation won't continue because there is an existing bad sector. How do i fix this and resize the partition successfully?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
since its only the sectors you are having problems with just tick the bad sector box
then download partition magic which will only install on the good sectors on your hard drive
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance. Partition Magic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
Ubuntu is a linux operating system which can repair hard drives widows have corrupted and cant be repaired by windows operating systems
Hope this helps you
