Question about Cameras
We have a Sony Cybershot DSC-W1. When we turn the camera on it fails to start properly. The lens moves a little, it beeps 18 times and then displays "Turn the power off and on again". We have tried changing the batteries, but it has made no difference. When we turn it off it moves the lens, but does not bring it fully back. Any tips appreciated.
  • 477 Answers
Goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Posted on Apr 30, 2008
The battery door does not close properly. Can it be fixed?
Probably, but the cost may be more than the camera is worth.
Sep 27, 2016 | Sony Cybershot DSC-W7, DSC-W5,...
Well actually my camera is a cybershot dsc-w100 and when i push the on button it says access but after that it goes to a mode where it says turn the power on and off again and i turn it off but still does...
Lens errors (access errors on Sony's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 01, 2011 | Sony Cyber-Shot DSC-W1 Digital Camera
The lens keeps on moving in and out and there is a sign on the screen to turn off and back on the camera... I have a sony cybershot dsc-w55
I have a cybershot DSC-P5 that was doing this. The plastic ring around the lens that is glued to the casing had become warped. We simply popped it off, brushed/scraped the excess glue away and put the casing back on, now it works fine! Just store it properly and keep an extra eye out for dust coming in where the lens used to be.
Jun 28, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cybershot DSC W1 Autofocus not locking
hi ,this is a problem of lence flap, the flap is in middle of the lence barrals if you are a tecnition then replace it otherewise please dont try it at home,or contact tecnition its not a big foult its rutin problem
Aug 27, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Lens will not retract
I have exactly the same problem and I found out that new batteries solve the problem. I also think the battery charger bundled with the W12 version is not very good. You might try (I haven't yet!) a new charger which handles new types of batteries (Ni-MH).
Feb 17, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Lens stuck open
I have to agree with one of the comments previously posted. I too had a Sony DCS-S700 and the lens was stuck open. Whenever I turned the camera on, the Sony Cybershot logo appeared and dissappeared, turning the camera off. I noticed the lens was crooked, so I moved it in the center direction and the camera worked again.
Mar 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony-DSC W1 lens not closing
batteries may be low. Dont force it unless its your only option. You could strip a gear.
Mar 02, 2008 | Cameras
Carmera not opperating
lens alignment or onboard memory problem , try using a memory stick instead of onboard memory ,and LIGHTLY TAP THE LENSE if you can get it out. if that doesnt work i suggest to go to a sony repair center
Sep 27, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Access
Hello, there is a problem with the optical unit (lens). Normaly when the camera is in camera mode the lens should go out. In your case it seems that for some reason the lens is stuck. Please contact your nearest Sony dealer. If you want to repair the camera yourself please tell me. I can send some additional info as well. Regards, Arpi
Jul 12, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Cameras Logo
103 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
