Question about Apple M9034LL/A Keyboard
None of my Keys are working
I have tried both USB ports and attempted to clean but it Still wont work
    President:
  • 8,637 Answers
Did you install the CD software program that came with your keyboard and mouse?
If you did try the following:
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 20, 2009
Install my printer, have a message about USB port MALFUNCTION in my printer BROTHER DCP7020 laser
Hello, Jorge.
It would help to know "exactly" what the error message states, such as "The USB Device Not Recognized" or something like that. Here are a couple of things to try in order to narrow down the problem source:
1. Try a different USB connection on the computer. If that one works, the problem is probably that other connection port.
2. If none of the ports work with the printer, try a different USB-powered device, such as a cell phone and charging cable. If it works, the problem lies with the printer/computer connection (more likely the printer).
3. If none of the USB ports work, the problem might be your USB port itself. Go to "Device Manager" (in Control Panel), then look for "Universal Serial Bus controllers." Check to see if any have a disabled symbol. Check under "Properties" that device status is: "This device is working properly." If not, try updating the drivers (under the "Driver" tab).
Jan 08, 2017 | Brother DCP-7020 All-In-One Laser Printer
How do you open a port
  1. USB ports stopped working Acer Aspire 5750 - Tom's Guide
    www.tomsguide.com/.../usb-ports-stopped-working-acer-aspire-5750.ht... Apr 23, 2014 - USB ports stopped working Acer Aspire 5750. Tags: Aspire. Laptops... I have an Acer 5750 none of the USB ports work I tried disabling them all ... on Acer Aspire 4935 laptop Forum; Acer Aspire Computer - USB not working ...
Jul 11, 2015 | Acer Aspire Computers & Internet
Usb ports wont work on a1217n pavillion desktop
None of them? Front or back? Turn on the computer and notice the screen to see what key ist says to hit to get into the Bios or System Setup during the boot process. Once you get in look to make sure the USB is enabled.
Hopefully you are not trying to put some new device into the port that might be too advanced for your system. Some systems can't handle things like a 1TB external drive.
Make sure you try something in the usb port that you know worked in the past and try different ports.
Apr 30, 2012 | HP Pavilion a1217n Desktop PC
None of the keys are working
Try a regular usb keyboard to make sure it is functioning properly
If so may need to replace keyboard
Also try a different usb port
Jun 25, 2011 | Targus USB Ultra Mini Keypad Keyboard...
When i plugg in my camera to the computer it wont chrge it wont even turn on if there is a soultion please contact me asap!!!
Hey Sophia,
Have you checked the battery, as the problem seems to be with battery
First of all checked if the battery is inserted properly
Take it off and re-insert it... make sure the +ve and -ve are set properly
If it still does not work...you got to replace the battery
Thanks
Oct 08, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
It wont show up
Have you tried alternate usb cables and usb ports on your system? have you tried a different system? If that doesn't resolve the issue- you have a dead external drive- if swapping the cables works, you have a dead cable. If swapping the port that you are connecting to- it could be the port is bad, or the port is a low power port. If swapping to a second system works- and none of the ports on the other system works- then the system will need service- either for reinstalling windows, or a replacement motherboard since the USB has failed.
Oct 03, 2010 | Western Digital My Book Essential 1TB...
My wireless keyboard suddenly is not working, almost all keys. Battery is good and some keys work, but it's not normal
Things to try:
  • unplug USB connector and plug in a different USB port if available
  • locate wireless reset button and press, type various keys over the next 10-20 seconds
  • clean keyboard thoroughly
  • reinstall keyboard drivers
  • last resort: check warranty and replace keyboard if still under warranty
I hope this helps.
Nov 10, 2009 | Microsoft Computers & Internet
Old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Sep 08, 2009 | Targus Noteworthy Multimedia Keyboard...
Keyboard frozen/none of keys will work
Make sure it is plugged in securely. Try a different keyboard. If it is a USB keyboard try a different USB port. If it still won't work write back.
Jan 23, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Unrecognized usb devices
If they work without the the expansion unit, the unit is not passing the power through. Many work this way. Some will work with external power.
Nov 06, 2007 | GE JASCO (HO97878) 4-Port USB Hub
Apple M9034LL/A Keyboard Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
