Question about Apple iPhone Smartphone
Iphone trouble My calendar works but I can't touch the second week of each month? First week any day is fine and third week is fine but I can not touch any of the days in the second week. It also has trouble with emails in that area.
    Genius:
  • 1,673 Answers
The touch screen and or the ribbon cable assembly is defective. The phone will have to go back to Apple or their authorized rep for service. They will replace the touch screen and or the ribbon cable assembly to it.
Jerry G.
Posted on May 02, 2008
Calendars have disappeared
The likely cause of this problem is that you're synchronizing your iPhone Calendar with iCloud or another online calendar service and your iPhone is set to sync only recent events. This option can be found underMail, Contacts, Calendars in your iPhone Settings app. The default setting is one month, however you can tap on this option and choose from either two weeks, one month, three months or six months or simply choose All Events to sync everything in your calendar.
New events created in the iPhone Calendar outside of this time frame are still saved and synchronized to your online calendar (e.g. iCloud), but once the online calendar has been updated, they are removed from the local iPhone Calendar; hence these events appear to vanish shortly after you've created them. Items you have created on these older dates will actually have been saved in the cloud and you would likely be able to see them on a desktop computer; iCal for Mac, for example, automatically synchronizes all events from iCloud to your desktop calendar, regardless of the setting on your iPhone. Further, if you're using iCloud you can log onto iCloud.com from any web browser and you should see these events in your Calendar there as well. In fact, if you adjust the sync setting above to a longer time frame-or All Events-all of these "lost" events should automatically be synced back down from the cloud and reappear; you'll likely even see all of the instances of events that you tried to create multiple times.
Ultimately, unless you have a very large calendar going back several years, it's probably best to just set your sync events preference to All Events, which will ensure that your entire calendar is available on your device and avoid any future confusion with vanishing events.
Oct 09, 2014 | Apple iPhone 4 Black Smartphone
How do I customize a repeating date on my iPhone calendar?
Tap the calendar icon and open the calender
Locate the month and tap the day you want to set and repeat.
Tap the + on the top right of the screen
Fill in the desired information about the day/event
3rd option is Repeat, tap it, open the option, and select how often you want it to be repeated.
Aug 07, 2011 | Apple iPhone Smartphone
How does its year calendar work?
The day at a glance calendar system used in this Orient watch, has been used in a number of watches over the past 40 years, perhaps most famously in the Wittnauer "2000" watch (which Orient actually made for Wittnauer under contract). Orient itself has used this system in a number of different styles of watches. Note that the daily date window is separate from the day of the week / month at a glance system; the date window is driven in traditional fashion by the movement.
The day/month at a glance system is based on a single disc inside the watch that is manually advanced by the user. If you look at the top of the watch, where the months are listed, you'll see little two-digit numbers. These represent different years--"04" refers to 2004, "11" to 2011, etc. To get the right days of the week at the bottom of the dial, you move the appropriate year under the current month. That will line up the days of the week--Monday, Tuesday, etc.--with their correct dates. You may see the same year repeated more than once on the upper part of the dial because the calendar has a specific pattern that can be replicated.
On older watches using this same system, the top pusher was used to adjust the date window, and a separate winding knob controlled movement of the year/monthly calendar disc. On this specific watch, which I have not handled in person, I cannot see a separate crown to adjust the date, and so I am guessing that you would pull out the set stem part-way to engage the disk setting mode. This would make sense because unlike the date window, where the date is always advanced, the year must move both backwards and forwards to align with all the months in a given year--you'll see that January and October are in the same place on the dial, for example.
If you're interested, here's an example of a vintage Orient that uses this same system for its calendar. Note how the monthly calendar and year/month alignment are flipped from the watch you asked about. Please note that I have no connection with this web site, make no endorsement as to the price being asked for this watch--but it has a nice picture of a classic Orient:
http://forums.watchuseek.com/f30/$128-all-steel-orient-perpetual-calendar-xl-case-vintage-watch-526811.html
On a final note, you'll see a number of people refer to these as "perpetual calendar" watches. That's not accurate. The year / days of the week disc holds about 20 years of calendar information. After that, the disc is no longer accurate, though you can easily keep aligning the monthly calendar just be referring to a printed calendar and adjusting it that way. For a period of time (not sure if they still do it), Orient would accept older watches with this system and change out the old year/day wheel with a new one that went further into the future.
Jun 03, 2011 | Orient CEUAA002WW Wrist Watch
Yahoo! Calendar Problem (code 40) The Yahoo! user nouser does not exist or does not have a public Yahoo!
For years, I have maintained two yahoo calendars: a work calendar and a personal one. I open the work calendar every day and then, in a different tab, open the personal calendar through Sharing.
A week ago, my personal calendar was inexplicably updated to the NEW format. I can no longer access it through Sharing. I am told:
The Yahoo! user nouser does not exist or does not have a public Yahoo! Calendar.
I have updated Firefox for the new Yahoo. I have re-assigned the Sharing. Nothing works. What can I do?
Jan 20, 2011 | Yahoo
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
Your kidding me? You can't do biweekly calendar entries?
I dunno ... im not trying to kid you ... read on friend.
You don't say what manufacturer or model phone you have ... It is pretty hard to believe that you couldn't do enter bi-weekly entries in your calendar ... BUT - you make it real hard to answer your question by omitting KEY details like make and model! (are YOU kidding ME?)
Something I would suggest you try, in the absence of fact, enter monthly events for the (for example) first week of the month for one year (you fill in the blank) THEN ... enter monthly events for the third week of the month for a year.
that would be the same bottom line I think.
thanks for your interest in FixYa.com
please vote
thanks
a
Dec 05, 2009 | Computers & Internet
How to insert Contact into Calendar on iPhone
I've been using an iPod touch for about seven months and to my knowledge there isn't a shortcut like this in the iPhone OS.
Aug 30, 2009 | Apple iPhone Smartphone
Can't get the day of the week to go with the month and date
You have to set the calendar for the correct year. To see the year, you have to press the time & month/date buttons altogether. You will see the display change from month/day to year. Use the set+/Set- buttons to change the year to the correct calendar year. This will fix the day to work with the month and date.If you keep having this problem, you will need to change the internal battery. I hope this information help you with your problem.
Apr 08, 2009 | Emerson Smartset Clock Radio
LG KP500 Cookie bugs - Calendar Alarms and Sync
I have a lot of problems with the calender. when I first got the phone, a week or two ago, I put my work houres in it, and the whole week, no alarm. then weekend came and a small icon above of a small calender appeared, and the whole weekend it kept on going off 5 times in a row at 7.30, the time I needed to leave for work in the week, when it didnt went off at all O_o today, I had to leave at 8.30 and it went off at 8.30 but also at 7.30 again, while that's not an alarm in my calendar for today.. after work my cookie suddenly went out, I had to take the battery pack out to "reboot" it, now the calender icon is gone, I wonder if it will go off at 8.30 tomorow like planned or if it won't go off at all anymore again..
Another thing I noticed is, that when I put in a date from one houre to another is that it doesn't state the correct houre (when I put in 8.00 to 16.00 it shows 00.00 to 16.00) I put in until I open the actual appointement.
strangely enough, my cookie just lighted up it's screen as if I touched it out of itself and even more strange, the calendar icon up there is back..!
Mar 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Sync iphone to outlook
Only way i could get any sync was first strangling the cat,wrapping its limp body round my neck,then getting two pieces of celery of equal length.Soaking these overnight in a mixture of lemon juice and urine.Drink the juice at 2 minutes past twelve on a full moon,insert the celery where the sun dont shine and whilst hopping on one footand circling the p.c with the iphone balancing on my forehead.First few times no joy then bingo synched right off.
hope this helps
Jun 30, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
26 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
