Question about JVC AV-27D305 27" TV
JVC TV - BLACK HORIZONAL LINE ACROSS THE TOP OF TV
First of all this 27 inch tv is about 5 years old and I don't know the model #.
After moving my tv set onto a new tv stand. I noticed that now when turning it on it has a wide black band across the top of the screen.
Can I fix the problem or does it need to be repaired by a tech?
Let me know also if it's worth getting fixed.
The vertical circuit is not pulling the top of the picture to the top of the screen (CRT) correctly. Its possible you have a loose wire or device ( after moving ) . If you have vertical agustments on the back , you may be able to adjust the picture taller; if the picture becomes stretched ( non - linear ) then you definately have tv tech only problems. At that point I'd really think twice about a repair and consider a new DTV or HDTV set. If the unit was damaged by a mover , then you may have a claim against them .
Posted on Apr 30, 2008
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Apr 18, 2008 | Toshiba 42H81 42" Rear Projection...
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
JVC model AV 278p6 standard television
I'll bet you have vertical output IC with some pins not soldered. This IC ( integrated circuit) is a "chip" that makes the picture fill out from top to bottom. After a period of time heat will cause the pins to crack loose on the circuit board. You need to have a tech check it for you. Stargazer
Aug 16, 2007 | JVC AV-27530 27" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
JVC AV-27D305 27" TV Logo
117 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
