Question about Saeco RIO Vapore
Rio Vapore Problem: Steam Leak
The Rio has a steam leak. It will emit steam and water from the valve even when the push button is in the off position.
Which parts should I replace to fix the problem? Which company is the best source for parts?
Costa Mesa
  • swstates Mar 19, 2009
    My Starbucks (Rio Vapore) keeps dripping water after the coffee button is pushed to shut it off. Any thoughts, anyone?
  • 515 Answers
Hi Mike,
There are a couple of gasket you need to replace in the steam valve, if the steam pin is worn, then you have to replace that to.
Posted on Jul 12, 2008
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
Fixing traditional home espresso coffee machine, Gaggia, Saeco, La pavoni,...
Fixing traditional home espresso coffee machine, Gaggia, Saeco, La pavoni, Rancilio, Francis Francis
FrancisFrancis X1 , X5, Gaggia Baby, Nuova Simonelli Oscar , Ascaso Dream , Gaggia Classic , Rancilio Silvia Rancilio Silvia
The in formation on this page is for use of technicians and experienced persons. All others do so at their own risk.
Traditional Home Espresso Machines Have the Following Parts:
1. A brass or aluminum boiler (16 to 40 oz. capacity).
2. A boiler outlet valve to help increase the pressure of water, before it is pumped through coffee grounds.
3. An oscillating pump with or without external thermostat.
4. A steam valve with a knob to open & close steam/hot water outlet.
5. Thermostat to limit temperature of water or steam.
Limit for espresso water temperature: 90°C to 98°C
Limit for steam temperature: between 127°C to 152°C.
6. A thermofuse to shut power supply when temperature in the boiler exceeds the higher limit (usually 185°C).
7. Solenoid valve (selected Gaggia models only).
8. A filter cup holder handle to place ground coffee for extraction of espresso.
The pump models generally are easy to open. In most brands, the top cover is fixed with two to four screws. In the Barista/Rio Vapore models, the top cover curves around to the back and the top has two screws. The front end has about 1/3" 90 degree fold. This folded lip is wedged between two plates. It may be necessary to use a long screw driver or other rod, pushed under the top cover, alternatively on either side of the machine to nudge the cover free and lift up. Note the slide along the left side in the picture below. Once the top cover is taken off, the entire internal set up can be viewed. The pictures below show two popular models:
1. Gaggia Model Espresso (without solenoid valve)
2. Saeco Espresso Classico (rapid steam model)
If you find this helpfull please remember to vote for it
on Aug 13, 2010 | Coffee Makers & Espresso Machines
My solis SL-90 machine has started to leak steam out of the steam wand. I'm noticing any problems with coffee or steaming milk yet but the leak seams to be increasing. I'd like to take care of the problem...
Your valve is out of adjustment. Everybody thinks that the valves opens to allow water or steam through. It doesn't. When you twist the valve it pushes a needle open to allow water/steam through. When you close the valve it allows the needle to seat, but if you keep twisting the knob it gets out of adjustment. It just moves the valve farther from the needle.
First unplug the machine. Remove the water tank. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 Allen screw. Loosen this screw and the rotate the cam counter clockwise until it stops. Push it to the left as far as you can (it should touch the screw on the left), then tighten the Allen screw. This is the proper adjustment. Reinstall the top. There is a grove in the top that the face fits into. Gently push the top back and the face will go with it. Then put the screw in the back and your done.
Feb 02, 2011 | Solis Crema SL-90 Espresso Machine
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
ESTRO VAPORE / Thermostats verification ?
Using an ohms meter, disconnect one of the leads and check the reading across the terminals. Make sure power is off when checking resistance.
May 01, 2010 | Saeco VIA Venezia
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Coffee Makers & Espresso Machines Logo
272 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
