Question about Nikon Coolpix SQ Digital Camera
Nikon Coolpix SQ
All the functions on camera works, but the lcd is off...
Any ideas?
  • 13 more comments
  • nightshade61 Apr 30, 2008
    hi.
    No i not get any menus at all.
    The lcd is off, backlight off.
    All other functions are 100% ok. All ready opened the camera and all the connections are ok. But the lcd doesn´t work at all.
    I have read the service manual and find out that is a fuse that control the backlight, dont know if thats the cause.
    If you can help .... i like very, very much this camera
    regards
    can you be more precise?
    there is a fuse for the back light in power board the fuse is f5.
    that fuse you say i dont now. can you give me a more precise ideia, or send a email with the location?
    i have the service manual. the f5 is on the power pcb. i think you say that the fuse that talk about where in the main board near to the connector CN500, that is the LCD connection on main board.
    i will try to by pass f5 when i arrive home.
    i´ll be back to post the results by the seven o´clock.
    i hope you can track this post with me so that togheter we can fix it.
    sorry the fuse of tft backlight (18v) is not F5 is F4...
    i have just take a better look to service manual..
    hi
    back again
    F4 missing. There´s a C on here should be the fuse
    F5 is there but i dont know if that is the right fuse.
    Any ideias?
    Do you all ready open one of this cameras?
    the fuse you talk is on the power board right?
    Do you have the service manual?
    Can you give more detail to find anything?
    I made a test when i came home, and connected to tv and it´s all ok. only the lcd don´t start. and i can´t find the fuse.
    F5 on the manual said that is for power supply from de cool station...
    ok.
    i try here of find something to.
    i have tried to reassemble the camera again in order to see if anything works and the problem is the same...
    everything works but no lcd...
    yes.
    another lcd from another camera nikon it flicks but continues to shown no image
    and the lcd from coolpix sq in another camera flicks and starts but i can´t fire up backlight so o can´t see no image but it flicks on another camera.
    do you know the power of this lcd backlight?
    i´m prety sure that is a power issue but i don´t know from were.
    can´t find the fuse....
    F1, F3, F5 are green
    F4 missing or a black smd piece with a C, and it says C42.
    backlight connect to 12v it lights it self....
    lcd connect to other board flicks...
    power issue.....
    help.... done all the possible tests
    i can´t they are diferent achines and lcds
    one is a nikon coolpix 990 and the other the square
    can´t do it.
    i´m going back to the f4 fuse and try to bypass it.
    i will be bck in a moment....
    30mins
  • nightshade61 May 01, 2008
    nop. it as not the fuse....
    i byepass the fuse and is the same thing lcd dont work.
    out if ideas.............................
  • nightshade61 May 05, 2008
    hi, again....
    LCD still not working, not sure but think the power of the backlight is off. Anyone have this problem, and know how to solved?
    thanks, again...
  • Mike Johnson
    Mike Johnson May 11, 2010
    do you get any menu listings when you push the menu button. also what model is it.
  • 477 Answers
There is a fuse close to where you back light is plugged in look for ic info of fu to see if it is the problem by pass the fu fuse and if it is it it will came on.
Posted on Apr 30, 2008
  • 5 more comments
  • Mike Johnson
    Mike Johnson Apr 30, 2008
    have you found f5 ??? if so jump the two connectors with a wire and see if the back light comes on.
  • Mike Johnson
    I am always on and glad to help
  • Mike Johnson
    yes I have I just donot have one in stock to look at right now.
  • Mike Johnson
    I will see if I can locate something
  • Mike Johnson
    Have you tried a new back light or LCD from a used camera?
  • Mike Johnson
    swap out the black light they are very small solder joints. But that should fix it the lcd and backlight seporate.
  • Mike Johnson
    the lcd between the two will now work you need the exact Nikon make each on preparatory to each camera I had the same problem they look like it would work but they are diffrent.
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
Stuck Zoom Function On Nikon COOLPIX L20 Digital Camera
U obviously broke more that just the lcd screen. Your lens assembly is now fubar so you will have to pay the piper to fix it. Or just get a new camera.
Aug 28, 2017 | Nikon COOLPIX L20 Digital Camera
Camra fall accidentially and lcd cracked but camera functions normally. i want to change lcd because another fall would damage lcd completely. what are the charges of changing lcd?
The price is around $23.37- £25.99
Here is a link to a display repair kit
http://www.aliexpress.com/product-fm/378278603-Nikon-Coolpix-L20-REPLACEMENT-LCD-DISPLAY-REPAIR-PART-wholesalers.html
Thanks
Mar 06, 2011 | Nikon COOLPIX L20 Digital Camera
Where can i download a user manual for nikon cool pix sq camera
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa.
Sep 30, 2010 | Nikon Coolpix SQ Digital Camera
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
System error
http://www.fixya.com/support/t248852-sytem_error
Mar 17, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon E5700 digital camara. Camara turns on, everything looks good, shutter opens but only see black through the view finder, monitor and will only take black pictures. I reset camera to factory...
There is a service advisory out for Nikon E5700.
t has come to our attention that in a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras, an electronic component may, in some instances, fail affecting your camera's performance and/or operability.
While only a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras are affected by this advisory, if your camera presents symptoms that can include (1) images with a strong color tint, (2) images that are totally black and/or (3) images with visible defects, Nikon will, upon confirmation that the problem is associated to this Service Advisory, service your camera free of charge.
link to info is here: http://www.nikonusa.com/Service-And-Support/Service-Advisories/index.page
Feb 27, 2008 | Nikon Coolpix 5700 Digital Camera
No Manual
Here is a link for the user manual for your camera. Hope this helps.
http://www.nikonusa.com/pdf/manuals/coolpix/CPSQman.pdf
Feb 03, 2008 | Nikon Coolpix SQ Digital Camera
LCD blank & No picture taken
This appears to be a well known CCD problem, which Nikon acknowledges only for the COOLPIX 3100, 5700 and SQ models. Nikon denies the CCD problems on the 5400 are related, even though a Google search for this problem returns numerous results which claim the same defective Sony CCD sensor was used in the 5400 as was used in the 3100, 5700, and SQ models. See this reference: http://www.stevesforums.com/forums/view_topic.php?id=65777&forum_id=21
Jan 02, 2007 | Nikon Coolpix 5400 Digital Camera
System error
turn it on and off 6 or 7 times while banging on the body beside the lens. worked for me, cameras been out of commission for 3 years ,apparently lenses tend to stick on coolpix cameras
Dec 17, 2006 | Nikon Coolpix SQ Digital Camera
Nikon Coolpix SQ Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
