Cant find my filter o a hotpoint first edition
  • meatologist Jun 18, 2008
    I have a WMA56 and need to find the filter as when I put on a wash it stinks of egg!
    Unfortunately it's not egg nog, as that would be fine because that would mean I could drink it.
    Can someone please tell me where the hell the filter is and how to access it?
I cant find the filter on my aquarius either, but i just read somewhere that this egg smell is probably caused by u mostly running the machine on cool washes i.e 40' ? so its suggests u run the machine on a 95' empty wash using ure normal detergent 2-3 times a year as the smell is a build up of bacteria because your washes arent hot enuff to kill it. If ure egg smell is bad, i'd do the empty hot wash thing a couple of times to make sure ! hope this makes sense?! :)
Posted on Jun 27, 2008
Were is the filter on the hotpoint wma40??
Posted on Feb 03, 2012
Where is the elusive filter located? I thought it was hiding under the flap thing at the bottom but I can't for the life of me work out where it is
If you were to Google "Hot point first edition FEW manual" using Firefox, the results will lead you to "for Hotpoint FEW washer - Laundry Appliances Manuals" at "laundry.manuals online.com>....> Hotpoint Washer".
Download a free copy of the instructions for Installation and Use for Hot Point First Edition Range User Manual.
I have looked through the manual and there is no direct evidence of a filter as such (common to other machines), but there are details of what maintenance should be followed to clean the machine - not too user friendly but may help.
If you do go to the manufacturers website (Hot point is an Indesit company) you will find that previous buyers have asked the same question as you)
Nov 16, 2013 | Hotpoint First Edition FEW12 Front Load...
I cant find the filter on the hotpoint first edition wma 20
i had this trouble for ages, u have to tip it on its side or bck as the filter is up underneath
Sep 29, 2011 | Hotpoint First Edition WMA20 Front Load...
How do we empty the filter on hotpoint first edition wma 10?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose, reassmble and test for leaks.
Have some cloths ready to mop up any water that may appear..
Jan 13, 2011 | Hotpoint First Edition WMA12 Front Load...
How do we empty the filter on Hotpoint WMA 12?
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Dec 19, 2010 | Hotpoint First Edition WMA12 Front Load...
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
My machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
Jan 02, 2010 | Hotpoint First Edition FEW12 Front Load...
How do I clean the filter on my Hotpoint First Edition FEW12? Do I have to take off the whole big black pipe at the back, under the drum? There is no filter at the fron
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Please rate my solution.
Thanks.
Nov 14, 2009 | Hotpoint First Edition FEW12 Front Load...
Where is the filter on my hotpoint few12 can i clean it myself
Hi.
If you cannot find a filter at bottom right of washer, then remove lower rear cover, locate and remove large black hose on bottom of drum, you will find the filter in there.
Thanks.
Oct 21, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Aug 07, 2008 | Hotpoint First Edition FEW10P Front Load...
Washing Machines Logo
587 people viewed this question
Top Washing Machines Experts
