Kyocera FS-9500DN Printerguru,   I need your assistance again, please, with my 9500. I have experienced deteriorating print quality in the last several days to the point where you can barely read 12 pt fonts.  I have replaced the toner, developer unit, drum unit, and the charging assembly one unit at a time. Nothing has improved the quality. I have reset the factory software setting via the control panel and the print quality setting are: KIR Mode: ON, EcoPrint Mode: OFF, Resolution 600 dpi, Print density 03. Changing these setting has no effect on output quality. Can you give some ideas on other troubleshooting tasks that I can perform? Or do you know what the problem might be?   Thanks Knarf77
  • Anonymous Dec 16, 2008
    i ahve the same problem on a fs 9500 and also on fs 9520DN. soo frustrating, has to be something to do with the charging of it, the 9500 wont even let me add toner by going into service>developer!
Benimur
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
M2Tech1
  • 313 Answers
SOURCE: kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
Posted on Jun 12, 2009
xptareq2000
  • 1447 Answers
SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Posted on Aug 27, 2009
Kyocera fs-c5400 toner usage
I don't think you are looking at coverage I think you are looking at toner levels
Aug 09, 2017 | Kyocera FS Office Equipment & Supplies
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
I have a kyocera fs-3830 F040 Failed what is the problem?
This error means - Communication error - Communication between the engine board and the main board is failed. IF there are no loose connections then yo most likely have a bad main board which will need to be replaced.
Dec 21, 2010 | Kyocera Mita FS 9500DN Laser Printer
Printer kyocera 3830n will not print..display reads clean tonner waste bottle..i have emptied it and also cleaned it
Try to reset the printer.
Factory reset on Kyocera FS-3800 printer:
Connect the printer via paralell and type the following in at the command prompt:
ECHO !R! FRPO INIT; EXIT;
Aug 25, 2010 | Kyocera Mita FS-3830N Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Jan 17, 2009 | Kyocera FS-C5015N Laser Printer
Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
318 people viewed this question
jasbo
jasbo
