Question about NorStar M7310 Corded Phone
Changing employee name on extension
WE HAVE PHONE LINE AT WORK WITH FORMER EMPLOYEE NAME ON EXTENTION. HOW CAN WE CHANGE TO PRESENT PERSON'S NAME?
  • Anonymous Feb 18, 2009
    Neither the 'feature **admin', nor the 'feature **266344' works to access the system admin. The first leaves a continuos dial tone, and the second replies with 2 negative beeps
Http://www.phonserv.com/1_m7310_phone_meridian_norstar_phone_system.htm
This has PDF file that will give instructions.
Also this link has more instructions:
http://www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_systems.htm
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Posted on Mar 10, 2009
On our phones it's "Feature **admin" to get into the settings.
Push the button that corresponds with the right arrow that shows on the screen until you see "Names"
push the top right arrow to get into it, and you will see "set names",
push top right arrow again to get into it,
scroll right until you see the set # you want to change,
press the button corresponding with "Change" and type it in.
Posted on May 01, 2008
3 Suggested Answers
  • 25 Answers
SOURCE: HOW TO CHANGE NAME ON THE EXTENTION LINE
at the PBX
Posted on Dec 12, 2007
  • 4 Answers
The manual was no help but this website was a lifesaver
http://norstarsupport.com/Support/DR5_Chg_name_phone.htm
Posted on Mar 11, 2009
Names are different on voicemail and extentions how do I change them on the voicemail
Hi Denise,
You should generally delete and re-add mailboxes when someone new takes over an extension. It allows the new person to customize the mailbox from scratch.
If all you want is to change the name, go:
Feature 983
Password: 1020000
Select Mbox
Enter the Mailbox number
Hit Next until you see the name, and then select change.
Enter in the new name, press next, and then hang up.
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
Voice mail display & retreving messages
Do you know how to get into phone system programming? The extension names are changed in there.
Mar 10, 2010 | NorStar M7310 Corded Phone
We have a Toshiba DKT 3210-SD phone system and can't seem to figure out how to reprogram the name of the person that is using that phone, The names located in the top left hand corner of the screen are of...
If you have the software you can get in and program via station assignment.
If you admin, programmed on any ext you can program.
If not we can remote into your system and change them.
info@ameritelnj.com
Tony
Jan 26, 2009 | Toshiba DKT-2020-SD telephone
Cannot change name ID for each extension, shows old names
Read several on-line manuals and found out another way to access programming trees. It was a confusing mess and was mostly trial and error. The 4 keys under the read out screen are a key factor and knowing how those buttons interact with each other is important. In the process I screwed up regular functions because the password that allows set-up using the feature codes cannot be changed. Not a user friendly set-up at all and the initial manual virtually useless for some needs.
Nov 25, 2008 | NorStar M7310 Corded Phone
Trying to change the name on a phone
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4
3.Press the top grey button (the set on the lower right hand side with the grey buttons closest together)
4. press the button under the one you just pushed until you get the desired name/ or the one with no name
5.press the same button as in number 3 (once only)
6.press the same button as in number 4 (2 times) you should get the name and a soft key button for change
7.type the name like a text message
8. once you filled it in hit the same button as in number 4.
9. hit release
Oct 06, 2008 | NorStar T7316E Corded Phone
Help
You needs to enter to a program mode inside the PBX option.
the name Its inside the PBX.
Once you on the Extension 101 enter program mode press choose program 004 select the station number and put the new employee`s name.
Jul 11, 2008 | Panasonic KX-T7630 Corded Phone
Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Mar 11, 2008 | NEC DTU 8D-2 Corded Phone
You will have to go into system programming. If you are not familiar with it, you will need to call in a professional, as it is too hard to explain over posting.
Dec 29, 2007 | NorStar M7208 Corded Phone
NorStar M7310 Corded Phone Logo
2,381 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
