Panasonic kxp6300 laser printer. how
How do I connect this to a new hp pc running windows vista..is it a usb to parallel or serial cable and are there drivers to achieve this or should i just give up and buy a new printer??? losing the quality of laser printing though......
  • nicobar Apr 30, 2008
    I don't think i explained or you understand the prob which is the com-puter new has a usb port but the printer is a large plug parallel . is this feasible and do i need drivers for cable and printer and is windows vista too modern to take all this
  • nicobar May 01, 2008
    sorry Dave 117, but the rating of inappropriate was not meant to be disrespectful, but it is the only category that is usable if the prob has not been solved. I seriously need to decide if this is worth following up or maybe just throw my hands in the aair and buy a new all in one which I have not actually needed till now!!sso really, thanks for your efforts, you actually are appreciated!!
    Kind regards
    Nic(obar)
    Novelist:
    Scholar:
  • 134 Answers
Use a USB cable if your pc & printer has the ports.. But make sure you install the software before connecting the printer. Usually the software will prompt you are the right time to connect the USB cable & when to turn on the printer.
Posted on Apr 30, 2008
  • Dave117
    Dave117 May 01, 2008
    OK.. I just noticed several brands of parallel to usb adaptors made by various vendors.. So yes it's possible at a hardware level, but there is a cost.. And they are not really cheap. Maybe 40 to 60 dollars..? Then there is the issue of drivers. I have not seen any drivers for XP, let alone Vista. I wish I could help, but maybe there is someone out there thats actaully solved this. I'd need the hardware to make it work. If you want to chase this further, the adaptors are made by Targus & also Belkin. Also, in my experience, sometimes old drivers do work. Depends on what libraries have been changed.. Sorry I couldn't help further. Rgds,
  • Dave117
    Hey I just noticed you rated this as 'Inappropriate' - whats that all about? You might want to wait until we have finished before rating it, as you asked for help. I wouldn't have spent another 30 minutes of my 'precious time' working on this if I'd known you had done that. How rude. Thanks for nothing.
My PC has usb ports only. My hp 4550 laser printer has parallel port. How do I connect them?
you can purchase a parallel to usb converter. i have one for my panasonic dp 150 and works a treat. remember to select the usb port on your printer properties
Jun 30, 2010 | HP Color LaserJet 4550 Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Printer is not working with my new a6742p pc
Yes. It should work fine, but there are a few IFs:
IF the printer is still good...you said it's an older printer. Also, does the printer have a USB port, or is it so old, it only has a parallel port? Some newer computers do not have serial or parallel ports.
IF you don't have a parallel port on the PC, and you have no USB port on the printer, you can purchase a parallel to USB adapter.
You also may have to go the manufacturer's web site to download the drivers for the printer.
IF there are no printer drivers for your newer Operating System, you are up the proverbial ******* creek. I have a hunch you are concerned about how to hook it up because of the above mentioned parallel - USB port issue. The adapter will fix that.
Good Luck!
Apr 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Printer with parallel port not "seen" on my Mac
I've never had much luch running parallel printers on UNIX systems, it seems that a serial connection works without any trouble.
At any rate, have you tried hooking it up to a stationary windows machine, and then sharing it using windows networking.
Then, you could simply print to it by using SMB...
I've done this before and it seems to work fine.
Mar 04, 2009 | Ricoh Aficio 3800CMF Laser Printer
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
Conecting an older HP parallel printer to a new computer
Better if you get USB HP printer to use with it. The only way to use that what you have it to get a printer server that supports parallel cable and connect the print server to your router using Ethernet LAN cable.
Jul 23, 2008 | HP Computers & Internet
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
75 people viewed this question
k24674
jasbo
jasbo
