Question about HP Nc6320 Notebook
My laptop hp nx 6325 won,t power up
Hi thought it was the power lead was damage got new one ,put it in the back of the computer nothing no lights .even got a new battery but still ,nothing can you help ,uk member,thanks
  • 472 Answers
Unfortunatly if you have replaced the power pack (i will assume that what you meant by the lead) and the battery, then the only real thing it can be is the bit in the middle... The motherboard has suffered some form of damage or failure.
First things first though..
A new battery will not normally come precharged. If you can find someone who has a similar laptop, try to charge your battery in that and try it back in yours again. Also ask at a laptop shop if they could possibly try charging it up. They may make you pay for it, they may do it for free in the event you will become a customer =)
Get the power pack checked using a multimeter to see if it does indeed have the correct voltages and is working correctly.
If it is, then you may have a damaged power connector on the motherboard, though this is normally a problem you will notice as it slowly breaks away and you have to wriggle the cord to get it to work.
Failing those it will be a motherbaord failure. This is not a cheap repair. Replaceent boards will normally run almost if not more then the cost of the laptop. It's their way of telling you they have a sense of humor.
Posted on Apr 30, 2008
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
I have a HP laptop that won't power up. I put in a new battery, and bought a new AC adapter. Now lights nothing. It was running than just quick and I haven't been able to get it to come back o
Hi There,
If you've got a multimeter - test your AC adapter to see if it is outputting the correct voltage for your laptop. If it is, Then you've got an HP boat anchor. Unfortunately HP laptops are known for their overheating issues, and if this is the case, a lawsuit filed against said manufacturer means you may be able to be compensated for your loss.
Jul 18, 2012 | Computers & Internet
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
I need the pc suite to install on my hp nx6325 laptop powered by windows7
Please find the link below to be helpful
Choose the appropriate link to get to your driver.
hp nx-6325
Dec 11, 2010 | Computers & Internet
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
My Hp laptop (nx 7300) is displaing a (X) on the battery icon while the battery is connected.
hi there, try to perform power drain first. take out the battery and unplugged power adapter. hold and press power button for 30secs then release. put the battery/adapter back in then power on the computer. if same issue happened, this could be a battery issue. if unit is still under warranty have the battery replaceed. thanks
Apr 07, 2010 | HP Compaq nx7300 Notebook
Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Oct 18, 2009 | HP Compaq nx7300 Notebook
HP nx 7300
remove and, reinstall the memory...If that doesn't work disconnect each device i.e. DVD, wireless nic etc. repowering each time.
Aug 25, 2009 | HP Compaq nx7300 Notebook
HP Nc6320 Notebook Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
