Question about Sony PlayStation Portable (PSP) Console
Ctf file does not work
How can i use ctf file for thems in my psp? its version is 3.71 M33.
  • 97 Answers
You go on google and search "PSP themes" then find on eyou like. extract the theme with WinRAR or other extracting program and open the folder. connect your PSP to PC via a USB cable. go to settings>USB mode. open PSP and there should be a themes folder. copy / drag the .ctf file into theme. disconnect, then go to settings > theme settings > theme, then pick your theme from the list. since your running 3.71 M33, you may or may not have the ability to apply themes.
Posted on May 02, 2008
2 Suggested Answers
gabrielsimut
  • 97 Answers
SOURCE: ctf file wont work
you need a .PTF file for it to work. i dont know why CTF doenst work. all i know is that it happened to me then i got the theme from some where else and it was PTF and it wokred
Posted on Jun 01, 2008
How to lnstall a psp ctf file
Hi
1. Download the plugin
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
7. Also notice that you will at least need PSP FIRMWARE 3.90 OR HIGHER to be installed on your PSP in order to get these themes running... Or see the video
http://www.google.co.in/search?q=to+install+a+psp+ctf+file&hl=en&safe=off&sa=G&prmd=ivns&source=univ&tbs=vid:1&tbo=u&ei=L2YxTf_TCIzEvgObvpSqCw&oi=video_result_group&ct=title&resnum=4&ved=0CCIQqwQwAw
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
See the video
Jan 15, 2011 | HP Computers & Internet
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
.ctf file and .ptf file
A .ptf file needs to be flashed to the psp's internal memory. You need custom firmware in order to do it and there is a slight chance you can brick the psp.
Jan 15, 2009 | Sony PlayStation Portable (PSP) Console
Psp slim 4.01 M33-2 ctf themes not working.
hey dude.. dis is miguel jalandoni from philippines.. i also had dat problem.. but.. i realized something.. i noticed dat there are different cxmb's and der are specific ctf's for each... maybe ur ctf's aren't for the cxmb ur using.. wat i did was i got packed themes.. i downloaded it and when i opened the folder.. it was complete.. cxmb, plugin, and themes... use that cxmb and put the themes and those themes from that folder will all work :D hope i helpwd :D
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
The theme problem
1.Download CXMB for 3.90 off this website
2.Connect your PSP to the computer
3.From the file you just downloaded go to CXMB_for_3.90>CXMB_FULL and take sepluginscxmb and ._seplugins and put them in the root of your Memory Stick
4.Go to recovery menu and enable the cxmb.prx plugin
USING CXMB
1.Download a CTF file off from the internet somewhere
3.Drag the CTF file you download and put it in X:/PSP/THEME
4.Go to SETTINGS>THEME SETTINGS>THEME then select a theme that you have put on your PSP  and press X then press X on apply
5.Your PSP will restart and the theme you chose will be on your PSP
Oct 26, 2008 | Sony PlayStation Portable (PSP) Console
Ctf file wont work on my psp. but the site where i got my ctf file theme says that it works on psp 3.71 m33 version. my psp is 3.71 m33 version. why does it not work? what will i do?
you can try to check your ctf file using another psp,and see if it'll work.if it doesn't then the ctf file is the problem,you need to download and re-install it again,see how it goes.if still no dice,i suggest you try to look for other similar files to use on your psp.or you might want to upgrade your psp to 3.90 m33-2 at least to enjoy more options as far as themes is concerned especially the custom XMB themes (cxmb).if you have time you can check this channel: http://www.youtube.com/user/kr2008 .no guarantees,hope this helps.
May 05, 2008 | Sony PlayStation Portable (PSP) Console
PSP
You can update the PSP via the Network Update on the PSP, or by manually downloading the file onto a Memory Stick from http://www.us.playstation.com/PSP/About/SystemUpdate/pc.html
Apr 05, 2008 | Video Game Consoles & Games
Downgrade PSP from 3.80
It's impossible to downgrade your PSP from it's current version. I'm not quite sure why you'd want to downgrade, but maybe you should upgrade (If a version is available) again and see if you like that version better. ^-^
Jan 05, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
