Question about Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000
Hi!!
When I have to print in color the areas what are suppose to be black or kind of gray are green. I already checked the configuration and it's look ok. Do you think is a head-print problem?? or other configuration problem.
Thanks
    Scholar:
  • 79 Answers
I think there is ink contamination on the bottom of the print head. Remove all cartridges and then remove the print head. Wash the bottom of the printhead with hot water. After that dry with a cloth. Make sure its fully dry. (Toiletpaper does a good job of drying the printhead). Make sure no ink is leaking out of the cartridges. Replace everything and then run a deep cleaning test.
Good Luck
Hope this helps
Thanks for reading!
Posted on May 02, 2008
I have a mac. how do i set up so i can start printing
Go to Canon website put in your printer model number an get the drivers an software for mac! hope this helps !
Sep 26, 2016 | Canon 3811B007AA model imagePROGRAF...
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Jul 01, 2011 | Car Audio & Video
My Epson 1400 is printing blacks green. After gray 40 % all my gray and black is coming out green. what can I do to solve that, and please don't tell me to chane my printer I just boughted it 4 months ago.
The printer is using your color cartridge to print black and greys.
The black cartridge must be empty and will need to be replaced.
The color cartridge has depleted one of the primary colors required
to print black.
Both cartridges will need to be replaced
Feb 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Brandnew printer nwill not print colour
Hi super_um
Assuming you have already checked the color cartridge and ink
Type something in color and try to print
Do not use the Printer Icon, instead go through the menu bar and select print
On the the print dialog screen, click on the properties,
Under color: options: you will have options like the following:
Print in color
Print in B&W
Print in grayscale
(Depending on the Brand of the printer, the wording may be different)
Make sure you select "print in color" option and leave it like that always. On the other hand, if you select black, all the different colors will be printed in black or gray.
Hope this will work for you
Good luck
luciana44
Sep 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
Picture is Gray, does not show any color
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Mar 28, 2008 | Televison & Video
Canon PIXMA iP4000 InkJet Photo Printer Logo
277 people viewed this question
old marine
old marine
