Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker over flows with water
Water overflows ice tray
  • 828 Answers
There is an orifice that controls the water flow to the ice maker . If to much water is being fed to the ice maker it will result in an overflow. You may want to check the pressure of the water system in your house.
If the overflow is being caused by a continuous feed to the ice maker your electric valve supplying the water may not be reseating after it shut off electrically. If this is your problem obtain a new valve assembly to replace it.
Posted on May 13, 2008
SOURCE: ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
Los Angeles Sub-Zero refrigeration experts
Posted on Jul 23, 2008
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
  • 109 Answers
SOURCE: Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Posted on Mar 31, 2008
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
  • 89 Answers
SOURCE: Ice maker feeding too much water and overflows
There is nothing wrong with the icemaker if infact it is "overflowing". Be carefull not to confuse "overflowing" with the ice maker leaking. Nevertheless, if the icemaker is "overflowing" with water and is still making "BIG" ice cubes then you need to replace the water valve located behind the refrigerator in the compressor department. Hint: it is blue.... Also, you may want to hire an appliance person to do this for you. Should cost around $200 to have fixed.... goodluck..
Note: If you determine that the icemaker is not "overflowing" but instead is "leaking" water then you need to replace icemaker instead of water valve. One more tid bit of information for you, Its bad when I can look at the model number and know EXCATLY what your fridge looks like! This GE fridge will give you cooling problems in the near future. Turn off during thunderstorms, too many flicker's of electricty will burn up the computer board on your fridge costing you around $400 big ones.. More from my website on GE at:
Posted on Dec 02, 2008
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
After replacing ice maker assembly, ice is not getting made?
Ice maker is leaking water and causing the ice to freeze?
Ice maker is noisy and not making ice?
Refrigerator ice maker stopped making ice?
Ice maker leaks water into ice bin causing a glob of ice?
Amana Refrigerator leaking water from ice maker?
Ice maker leaking?
Ice maker is dumping the ice cubes out before frozen solid.
Water overflowing ice maker?
Ice cube is getting stuck up hard in ice maker
Icemaker quit working?
Quit making ice
Water leaking into ice tray, frozen glob of ice
Not making ice, and water leaking in freezer?
The ice maker stopped making ice?
Ice maker not making ice?
Ice maker quit working?
Ice maker dispensing black pieces of plastic in the ice?
Replaced Ice maker but its still not making ice?
Ice maker leaked creating an ice block?
Ice tray leaked?
Ice maker stopped functioning?
Ice maker stop working?
Ice maker failed
Old ice maker stopped working?
Old ice maker started leaking?
Ice maker not working?
Ice maker overfills and cause water to flow into ice dispenser and freezes?
Ice maker didn't make ice?
Ice maker was leaking?
Ice maker was leaking after it filled up with water?
These will help.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Not sure what model you have, but recommend you check to see if there's not a cube stuck in the dispersal unit. If not, then check plastic water supply tube in the back of the icemaker, sometimes they freeze solid and won't let water flow into the ice tray. I've had to use a hair dryer to defrost it if the freezer temp gets too low. Also, sometimes the ice maker inadvertently lets too much water enter the trays and it slightly overflows, which results in the freezing of the gears and paddles of the maker and you simply have to chip away the excess ice that overflowed the trays. If none of the above are the case, make sure you still have a solid water supply to the back of the unit, if the line runs outside of the heated portion of your home, it could have frozen outside of the fridge. Hope this helps.
Mar 03, 2011 | Maytag Refrigerators
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker is overflowing, I replaced the valve and the water is still overflowing the tray
This is usually a problem with the icemaker. The only fix is to replace it.
May 21, 2009 | Refrigerators
Ice maker water overflow
Sep 02, 2008 | Whirlpool ED2FHEXN Side by Side...
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Aug 23, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
1,125 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
