Question about Fuji Cameras
Our Finepix S2 Pro has shut down while I was taking pictures with the adapter without warning. It has not been able to be restarted. I have tried batteries, a new outlet and as of yet ...no luck. I was wondering if you have any helpful hints. Thanks
The solution was quite simple...it was the lithium batteries that needed to be changed.
Have fun.
Posted on May 01, 2008
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
My fuji FinePix S2 Pro is processing images with a blush tone through out my images. What's wrong with it?
Could be a white balance setting or you've accidentally engaged a digital filter. You could try a camera reset. Go into the setup menu and scroll to "reset". This will take you back to the default settings.
Sep 22, 2009 | Fuji FinePix S2 Pro Digital Camera
Battery problem S2 pro
Check your battery tray and that it has clean contacts. I'm sure you will find that if you place some pressure on the tray to push the batterys in just that fraction more when you take a pic that it will work fine and wont do the annoying beep and shut off. Maybe it has become a little loose over time and isint quite as tight on the contacts as it used to be.
Nov 02, 2008 | Fuji FinePix S2 Pro Digital Camera
Picture is black
take the lens cover off ? :)
Oct 27, 2007 | Fuji FinePix S2 Pro Digital Camera
S2 pro electronic malfunction?!?!
If your lithium batteries are depleted, having them in the camera will shut it down. A common cause of depleting the lithium batteries is leaving them in the camera while using the AC power adapter. For some odd reason, the Fuji engineers did not build in a disconnect circuit when on AC power. You should always remove the lithium batteries when using the AC adapter.
The Fuji S2 will run fine without the lithium batteries, except that you will not be able to use the built-in flash. Fuji recommends that as an "emergency" procedure, but I ran my S2 off NiMH AAs only for my heavy use over four years with no adverse effects.
If you buy the MB-16 battery pack or one of the modified versions for the S2, you would be able to use 8 AA batteries to power the camera, including the built-in flash, and never touch another lithium battery. The MB-16 itself does require some modification in filing off edges around the base and building up material around the post to firmly engage the switch you found.
Sep 29, 2007 | Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
Maybe your card is already def.
Aug 08, 2007 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
No picture
My S2 is on its second out of warranty CCD, and Fuji replaced both for free, the first was due to the same dead CCD as many has had, the second was due to the CCD being defective to the point of being off center and producing photos that had a very distinct leaning to the right, Fuji did not charge me for either CCD's, and if the tech said otherwise, if I where you, I would call them back and say you belong to many on line forums, and have read that Fuji is replacing them at no charge, its possible that the rep you talked to is unaware of this! That is another point, make sure you talk to an actual camera tech, and not just a rep, the rep will probably give you the run around.
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
