Question about Sharp Aquos LC-PD50U 50 in. Plasma Television
Using the TV as a computer monitor
I have a sharp PD5 (LC-32PD5X) and would like to use it as a computer monitor aswell as a TV but cant find a way of being able to get the comuter to show up on the TV please HELP
Regards
Graeme
    Brigadier General:
  • 6,966 Answers
I am assuming that you have installed the cable to the appropriate jack/connectors on the back of the TV and that of the PC.
If you are using a laptop, you would need to press on the Fn + F? keys of the laptop to cycle through the different settings such as: laptop's display only, laptop & TV displays and TV display only. The F? key would be one in your laptop designated to engaged/enable external monitor (TV). Normally, it would have a monitor icon.
Please verify that your PC's screen resolution is 1366 x 768 or lower.
If you are using a desktop, you need to engage/enable the dual/twin view in Display Properties. Additionally, the TV must be powered on first before the desktop is booted.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 30, 2008
My Sharp 55" Smart TV doesnt respond with remote
Try a different remote such as one for your bluray player to isolate if tv or remote
Nov 02, 2017 | Sharp Televison & Video
Schematic diagram of sharp tv
i need a schematic diagram of lc-32m400m-MBK
and H/LCD500142 Board allso
Aug 22, 2012 | Sharp Lc-32m400m 32" Multisystem Lcd Tv
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
Jun 04, 2017 | Sharp LC-32SB24U 32 in. LCD TV
Sharp LC-46SB54U Looks like something hit the screen (not cracked) but it looks like a cracked window with a few color bars streaming out from the impact point...Any thoughts about how to try to work...
has anyone had this problem? I was watching my sharp Aquos tv and all of a sudden I see a black line, then fuzzzy then black screen then a loud pop, now it looks like colors that sprawl out as if something exploded in one spot inside the screen and it looks like the inside screen is cracked. but nothing hit the tv. it just happend. the sharp people tell me that it cant be fixed or replaced. and they keep telling me i hit the tv! From 5 feet back??? I was watching it. he says..did you see anything strike the tv?? I was like, I am going to ignore that rediculous question because I was on my couch..and no one was in the room! he says the only way that happens is if someone hit it! OMG! i have only had this tv for 3 months and paid $2000 for it. why would I HIT my TV!! no one will help me. I have a master plan warranty on it aswell. they wont help me.
Mar 09, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can a Sharp XE-A404 be programmed to print department percents on a z tape?
No,u can't program it to print anything this is not a computer.It a tv,U can use it as a monitor for the computer that it.
Apr 27, 2010 | Sharp LC-32SB24U 32 in. LCD TV
How do I hookup my sharp liguid crystal tv as a pc monitor ? I have the analog RGB hook to my PC in but I cant see the picture.
If the tv is connected to your pc, then you need to go into your video properties and select the tv as your monitor.
Feb 15, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
Lc-32pd5x its a roof mount antenna not sure what brand it works fine on my other lcd
so you could not wait 1 minute while I wrote to you how to reset it?
by default from factory the pin code is 1234
heres the full user manual for your tv
http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
if the code doesn't work heres how to reset the tv
HOW TO SET THE FACTORY PRESETS
Turn off the TV by pressing POWER on the TV.
After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
TV.
All setting items (except TV channel) return to the factory presetting.
note Password will be cleared after running the factory presetting operation.
You can run the Auto Installation again by using the following steps.
1 Turn on the power of the TV.
2 Press MENU. (Make sure the menu screen displays.)
3 Press left or right to select “Setup”.
4 Press up or down to select “Auto Installation”, and then press ENTER.
5 Press left or right to select “Yes”, and then press ENTER.
Jun 17, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Can only see half the screen
all right you have a system error call xbox at 1-800-4my-xbox and tell them and send it in for reparis it takes two to three weeks not that bad free shping and if they can not fix your xbox they will give you a new one. i hope i helped you my email is tootles100@yahoo.com
Jun 07, 2008 | Microsoft Xbox 360 Console
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Sharp Aquos LC-PD50U 50 in. Plasma Television Logo
146 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
