Question about Whirlpool Duet GHW9150P Front Load Washer
Frotnt door seal ghw9150
Replace door seal
    Genius:
  • 1,028 Answers
Why ? is it torn and leaking or just mildew? if not torn cleaning best bet with chlorine bleach and water.if you still want to change it remove spring front front edge pull seal back toward drum on back section big clamping band remove band pull seal off and reinstall reverse order can be a dog if not experienced good luck
Posted on May 01, 2008
Door lock
These fault codes are caused by a failure of the main control circuit board (the brain of the washer), this is the board that is behind the washer control buttons.
Feb 07, 2012 | Whirlpool GHW9150 Front Load Washer
GHW9150 will not start, door will not lock. No codes on display Has power and water.
This means that the CCU on the rear of the washer has an electronic glitch. Try unplugging the washer for several minutes if this does not work the CCU would need to be replaced.
To do so remove the top of the washer. Three screws hold it down. The ccu is on the top of the washer. Remove the wires and place on new.
Let me know
Mar 26, 2011 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet washer will not start . Hear a clicking noise then receive DL F fault
The clicking sound is coming from the door lock/switch assembly trying to lock the door but it cannot. After six trials, the error code "FdL" shows up on the display. Press PAUSE/CANCEL button twice to clear it.
The only way to fix the problem is by replacing the door lock/switch assembly with part numer 8181700 and costs about $40-$55. Some vendors listed it as part number 1094190 or PS972231. Below is the replacement procedure.
Door Lock/Switch Replacement Procedure
  1. Unplug the machine and open the door.
  2. Stretch the retainer spring of the seal boot retaining hoop then remove it. The seal boot is the gray rubber around the door opening. The retaining spring is located at the bottom of the door opening. The door lock/switch assembly is located on the right side of the door opening.
  3. Ease the part of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot because it will cause water to leak from the tub.
  4. Remove the three screws securing the door lock/switch assembly to the front panel.
  5. Lift the door lock/switch assembly and pull it away from the front panel then pull it out of the machine.
  6. Disconnect the wiring harness connector and connect the new door lock/switch assembly.
  7. Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 20, 2010 | Whirlpool GHW9150 Duet Washer
Rubber seal on whirlpool waasher
If you are referring to the rubber door bellow, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, or require additional assistance, please post back and let me know. I hope this helps you.
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
Gasket is leaking
something has probably been left in a pocket and torn the front gasket or door boot as it is called. this will need to be replaced. it is not an easy job as the boot is held on by a large round spring.
Oct 11, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet Washer GHW9150PW1
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Mar 04, 2009 | Whirlpool GHW9150 Front Load Washer
Ghw 9150 lock mechanism problem
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Oct 14, 2007 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
282 people viewed this question
Dan Webster
Dan Webster
Sal De
