Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Arms wont spin
Pleanty of water, i can make them spin by pushing them but they wont spin during cycle
    Genius:
  • 1,073 Answers
There is a problem in the motor and impeller the impeller on the end of the motor could be loose this is what forces the water through the system for the spray arms to turn check the whit impeller on the end if not tight replace the motor assy
Posted on Apr 30, 2008
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Not pumping water out
if the dish washer is not pumping out water it could be a motor or a pump issue. the motor attached to the pump forces water up into the sprayer arms and during the drain cycle, this pushes the water out of the dishwasher. The motor and pump is normally under the dishwasher.
check and see if the motor spins. if it spins, then the problem is with the pump ,if it doesn't spin it could be a motor problem or a motor and pump problem.then test and replace the faulty pump or motor . hope this helps
Oct 01, 2009 | Bosch Dishwashers
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Sep 10, 2007 | Dishwashers
Dishwasher appear to be clogged
Sep 07, 2007 | Maytag MDB7100AWB Dishwasher
Dishwasherwont wash
Sep 04, 2007 | GE 24 in. GSD2120C Built-in Dishwasher
Dish washer
Aug 30, 2007 | Dishwashers
Washing
Aug 30, 2007 | GE 24 in. GSD2230Z Built-in Dishwasher
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Aug 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Fills with water but won't wash.
Aug 11, 2007 | Maytag 24 in. MDBH950AW Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
212 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
