Nile IRP2+ Hi experts, We have a simple Niles IRP2+ installed. This send our satellite TV signal elsewhere. Recently the satellite decoder was changed and now the IRP2+ is not sneding the signal to the other room. Any ideas? Frustrated Aussie
  • 156 Answers
Try a new flasher or a new IPR2+ ... I have had some Niles Emmiters fail.
Posted on May 01, 2008
Autosetup on my DVB is not picking up stations. The TV is connected directly to the satellite dish and has all free sat stations. As far as I can see all the connections between the TV and DVB are as
I'm wondering where in the mix is your satellite receiver? The recorders currently on the market aren't able to decode digital satellite signals. They are capable of decoding cable but i'm unaware of any that work on satellite.
Sep 17, 2014 | Panasonic Televison & Video
Niles infrared microsensor blinks continuously
1. The microsensor could be dusty
2. The remote could have a stuck button
3. Something is generating an infrared signal that the microsensor is detecting
4. Batteries could need replacement
Jan 01, 2014 | Niles Audio MS220 Surface-Mount IR...
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
My tv is plug into the cable box and wont pick up any channels when i auto program???
Do you subscribe to cable television? If you do, you will need a cable box to decode the signal, otherwise unless your local provider offers a free to air service, your TV will not be able to decode the cable signal. It is important to know wether you are connecting your TV to a cable socket, or aerial or satellite, as these are all very different signals which your TV may not decode.
Jan 03, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
I have an LG FS4D-UC Television. I recently
go to the setup in the direct tv menu. Then go to remote setup and follow the online instructions. Make sure that you are sending the signals infra red. The setup will tell you how. If that does not work. Go to direct tv support online and they will help you
May 10, 2010 | Televison & Video
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
