I want to use my Phillips 32pfl5332d as a monitor for my laptop. How do I connect them and make it work?
  • hotboymie01 Dec 31, 2008
    i have an jvc 52 inch and i don't have the manual guide for it so i can't hook my computer tower up to my tv it works for a second but then i go's to a no signal thing so how can i hook it up
  • 655 Answers
Please click here
  • On the above link there is details how to connect with pictures.
Hope it will fix your problem.
Please Post your feed-back.
Thanks
Iqbal
Posted on Apr 30, 2008
    Genius:
  • 3,422 Answers
To connect it you will need s-video connector on your laptop.CLICK HERE
All the procedure is mentioned.
Goodluck,
Please don't forget to rate th solution
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Screw size for wall mounting for Phillips 32inch. What is the screw size on the back that you would use to mount tv to wall
Get in touch with Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 28, 2015 | Philips 32PFL5332D 32 in. LCD Television
How to fi a phillips 20fp shuts off in 2 scs.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 29, 2014 | Philips Phillips 20" Color Monitors Model...
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
32" phillips tv turn self
If you go to this website, http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=32PFL5332D/37&slg=en&scy=US
You will see firmware information on the right hand side of the screen. Please open and read the Firmware Upgrade Read Me file. These contain instructions and the update history of this model TV. Underneath the Read me file you will find the download link. You must follow the instructions in the read me file or you risk damaging your unit further.
This is from the read me:
The set is switched OFF/shut down by itself after a few hours turning ON.
The newest upgrade should fix all your issues.
Hope that helps!
Jul 19, 2011 | Philips 32PFL5332D 32 in. LCD Television
My phillips model #32PFL5332D/37 flat screen will not come on
You have been the victim of a power surge. It will need to be repaired in order to work.
Sep 29, 2017 | Philips Televison & Video
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
Jul 24, 2009 | Televison & Video
I LOST THE INSTRUCTION ABOUT THE TV. I WANT TO SEE MY PICTURES ON THE TV, BUT I DO NOT KNOW HOW TO CONNECT IT WITH MY DIGITAL CAMERAL. I HAVE AV CORD AND USB CORD.
http://www.retrevo.com/support/Philips-32PFL5332D-TVs-manual/id/2782bh944/t/2/
You will find the manual please be sure you have a PDF reader www.adobe.com to download one. Please leave a good rating for me as I do not get compensation for finding manuls for everybody here, I rely on your good ratings, Thanks for using Fixya..
May 21, 2009 | Philips 32PFL5332D 32 in. LCD Television
Hp pavilion dv2000 black screen
You could have a faulty backlight.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 02, 2009 | HP Compaq nx5000 Notebook
I am having trouble linking my Phillips Monitor Model 17054 to my lap top, help?
Are you having an issue physicaly connecting the monitor or getting the laptop to output to it?
Aug 19, 2008 | Computers & Internet
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
