We have a Wireless network set up at home using Airport on a Mac with the Mac acting as the hub for internet access. Most of the computers in the house are Macs and work on the network quite cheerfully as does my work PC with XP installed. Our problem is we have just added 2 new laptops to the mix, 1 with XP & 1 with Vista. We ccan't get either to connect to our network. They can detect it but won't connect. We've tried every possible suggestion we can find on the net - none have worked so far, any ideas?
  • keamac Apr 30, 2008
    Thanks
    The static IP addresses did the trick. :)
    I have a happy husband & son now.
    Brigadier General:
  • 6,966 Answers
Have you tried static IP addresses on the 2 new laptops even if DHCP is enabled?
Additionally, pls try with the WEP, WPA or MAC Filter off/disabled.
Alternately, on the 2 new units, pls try configuring the Wireless LAN Properties Advanced tab to use "ANY" or your SSID.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 30, 2008
  • Louie  Role
    Louie Role May 01, 2008
    Glad to be of assistance and appreciate the rating too.
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
Tip
How To Use Your Mac As a Wireless Router
1) You need to configure your Mac (the one connected to your modem) to share its Internet connectivity with other wireless devices. To do this, select System Preferences from the Apple menu, and then click on Sharing.
2) In the Sharing window, click on the Internet tab to bring up Internet Sharing. Select Built-in Ethernet from the Share your connection menu. Then, select Airport in the To computers using list
3) Click on the Airport Option button to configure some wireless security options. You Only want to be sharing your wireless connection with Your Other computer. Enter a Network Name, select channel as Automatic, and enable encryption and enter a WEP password, which will be required to join your new wireless network. now click on Ok
4) Now your mac is acting a wireless router just connect to your network from other computers and enter the WEP key when it ask for it.
You found this to be an excellent solution when you don’t have a wireless router, but would like occasional wireless access in your home or small office.
Regards
Sandeep Shrivastava Founder & Owner of FixMyPCAndMac.com TotallyTechStuff.com Visit for More Solutions
on May 19, 2010 | Computers & Internet
Macbook and wireless n setup how do you set it up????!!!!!
Can you clarify the problem for me:
1. Mac Type = Macbook
2. Operating System = Mac OS ?
3. What are you trying to connect to?
For example are you trying to set up a Wireless Home network, meaning that iPhones, iPods or other macs can share the one Internet Connection. This is called a Computer-to-Computer Network.
OR are you trying to configure a Wireless Modem to work with your MacBook?
Setting up a Computer-to-Computer Network is done by:
1. Select System Preferences from the Apple Menu.
2. Select Network from the Internet & Wireless section.
3. Select Airport from the list of devices.
4. Click the Turn Airport On button, located next to Status. NOTE: If it is already turned on then this button will read Turn Airport Off.
5. Select Create Network from the drop down menu adjacent Network Name.
6. Type in the preferred name that you wish to call your network in the Name field. (ie., MacBookHomeNetwork or something)
7. Select the Channel (Channel 11) is an OK one to select.
8. Choose whether you want the user to type in a password to gain access to your network. (This is recommended.) If you do, then click the check box beside Require Password.
8.1 Type in the Password into the Password field.
8.2 Type the Password again into the Verify field.
8.3 Select the type of encryption you want to use, 40bit or 128bit.
9. Click the Show Airport status in Menu Bar check box.
NOTE: If you require advanced settings, then click the Advanced ... button.
10. Apply and then go back to the System Preferences window (using the Left Arrow located top/left of window). If you get stuck, get back using Instruction No.1 above.)
11. Click the Sharing Icon in the Internet & Wireless section.
12. Select from the list each item you wish to share (i.e, File, Printer, Bluetooth, Internet, DVD or CD etc...).
NOW : From your other device, you need to locate the new Wireless Network Connection.
If it is an iPhone or iPod then go to the Settings menu and select Wi-Fi from the list. The new network should be picked up automatically. Log in to it (if you set up passwords).
I hope this helps. Regards,
Feb 05, 2010 | Computers & Internet
How do i cannect my macg4 to my home network??
Ummmm by connecting wireless to a wireless access point that you would have (assumes you have Apple Airport Wireless option in your Mac) or by plugging in to a Switch/Hub (or router with a switch hub.)
Mac OS X should detect the wired connection and get IP Address and Router settings automatically ... just like any other computer.
If you have wireless in the Mac then you should have a radio waves looking Apple Airport Icon. You should be able to find your wireless network and Just Connect.
If all else fails press the Smiley Face button on the mac. :-)
(that was a joke.)
Mac OS X, now based on Unix Operating System, has very good networking sub system built-in. Should work without too much rocket science. The graphical widgets should help you get there.
It won't play blue ray disks though, I can tell you that much.
Nov 22, 2009 | Apple Computers & Internet
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Can't connect to the internet with my Airport Express
Make sure your network settings are set to DHCP manually and that you are getting an IP address that does NOT start with 169.258
If you are using a Windows PC you may have to use the ipconfig /release and ipconfig /renew to refresh your DHCP settings.
Also try using the Airport utility (located in the Utilities folder) if you have a Mac. It will tell you if there is an issue.
Dec 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Computers & Internet Logo
David Payne
David Payne
